After-market wheels and tire pressure sensors
Old Jan 29, 2007 | 04:38 PM
skyking9's Avatar
Unhappy After-market wheels and tire pressure sensors
just received my GT 40 chrome wheels, and found out goodrich could not mount because of tire pressure sensors. Ford can, but new bands for sensor cost $70 PER WHEEL! Anyone else have this experience, or did Freedom Ford see me coming?
Old Jan 30, 2007 | 04:08 AM
Stig's Avatar
You can remove and refit the sensors on your new wheels, but you will either need to get the replacement bands from Ford, or use a make-a-clamp hose clamp kit. You can get these for about $6 if I remember rightly?
See thread here
http://forums.bradbarnett.net/showth...highlight=tpms
It's straightforward enough to do. The Ford clamps are basically v.long hose clamps, but you may need a special crimp tool to secure them?
Old Jan 30, 2007 | 07:03 AM
skyking9's Avatar
Appreciate the tip
Old Jan 30, 2007 | 07:33 AM
SteelTownStang's Avatar
Yep... sensors are reusable. You'll just have to purchase the metal bands
Old Jan 30, 2007 | 07:41 AM
Stig's Avatar
No problem amigo
I found out about it as I have the same issue. I've got a set of GT500 wheels to replace my 18" Bullitts. I'm fitting the GT500 brakes, so need the backspace!
Old Jan 30, 2007 | 02:25 PM
GottaHaveIt's Avatar
I seen one this morning it's the base of the valve stem that is inside the tire, I think if the stem fits it can be changed but you may need to get a seal kit with the proper O rings, and who ever does it should have a wand that they calibrate each wheels sending unit with the cars pc , so it jnows which tire is which. cool but a more of a pain & cost then to change over.
Old Feb 1, 2007 | 03:04 PM
Stig's Avatar
There are 2 types of TPMS. One is a cradle type, which is held on with the band I referred to, the other is a valve fitment.
To the best of my knowledge, the 07 (and perhaps late 06) cars have the cradle type. Are you sure the wheels you saw were from a late 06/07 Mustang GT?
robjh22
4.6L GT Modifications
Aug 13, 2015 02:56 PM
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
junkman9096
Aug 3, 2015 10:58 AM
