Why aren't you running an oil separator?
#61
OK so whether I "need" it or not I bought one of these things . . .
Which is the correct side to install it on? I thought I remembered some posts saying it should go on the passenger side, but my order says "driver side" and when I checked with AM they said it is supposed to go on the driver side.
#62
Make sure you got the correct one as they make two at JLT and the most sold one is for the pass side of car looking at it from the front with hood open. Tucker say they dont need a drivers side unless you track the car
#64
Received 1,520 Likes
#65
#67
Yep it is about the easiest plug-and-play install there ever was, and it is quite obvious when you install it . . . . it goes on the PCV valve, which is on the driver's side on the 4.6
