Who is running 275/35/19?
Hey Tom, do you have any more information on this, or links? Any info here would be much appreciated. Now that you mention this I've seen oil pump/ gears and I was wondering what use case they were meant for... I know the Cobra Jet comes with some mods for high rpm: 1) M-6600-50CJ High Performance billet steel oil pump 2) M-12A227-CJ13 high RPM pulse ring Cobra Jet motor is capable of 8000+ RPM. I wonder if you're limited at 7300-7500 if you need to upgrade the oil pump as well
http://www.s197forum.com/forum/showthread.php?t=117586
I don't see why not. If the goal is better look, better grip, and more comfy ride than this will do the trick. Only side effect is it will change your final drive ratio to something close to 3.48 or so.
Thank you sir, much appreciated
