Where's the Oil Filter?
Old Mar 28, 2010 | 11:32 PM
PaulVincent's Avatar
Anybody know how easy/difficult it will be to access the oil filter on the 5.0? Thanks.
eci's Avatar
eci
Knowing Ford, it will be at an angle to make a perfect mess on the K-member.
Old Mar 28, 2010 | 11:33 PM
Ltngdrvr's Avatar
I think it is in about the same place as the 4.6, right up front. V6 is that way for sure.
Old Mar 28, 2010 | 11:49 PM
2010MustangGT's Avatar
https://themustangsource.com/gallery...?i=28995&c=915
https://themustangsource.com/gallery...?i=28994&c=915
Old Mar 28, 2010 | 11:50 PM
eci's Avatar
eci
Yep, at an angle. Thanks Ford.
One thing I love about all the GM's I have owned is the filters are straight up and down with nothing underneath them. I have to make a **** aluminum foil funnel on all my Ford's to avoid oiling everything up when I change the filter.
Old Mar 28, 2010 | 11:53 PM
Fazm's Avatar
you must have only changed oil on a couple gm's then, because they are 2nd only to toyota for stupid oil filter placement
Old Mar 28, 2010 | 11:54 PM
eci's Avatar
eci
Only LS motor GMs.
You ever change the oil on a new Tundra? LOL. Remove rock guard, remove little metal filter cap, stick plastic thingie into filter cap, draining the filter, remove filter cap, change filter media, replace filter cap, etc etc
PTRocks's Avatar
It's in a place that's _generally_ accessible, but will likely get the new z-member dirty. It's partially hidden by the blue diagonal brace just forward of the wheel centerline.
Old Mar 29, 2010 | 03:10 AM
Former 5.0 owner's Avatar
Oil filter location is one thing I like about BMWs. Right up front and cartridge style so with a fluid evacuator you don't even need to get under the car to do an oil change.
Of course they get a lot of things wrong, like no LSD on anything but an M car and no dipstick with the current generation.
Old Mar 29, 2010 | 07:54 AM
Overboost's Avatar
Worst oil filter location goes to the old FS-DE 2.0 motor in a ton of Mazdas. The filter itself is half the size of a soda can, and it's mounted about 2/3 of the way up between the firewall and the back side of the block, and on an angle so just about every wrench doesn't fit. No matter what you do, you spill oil on the half shaft and everything else around.
Old Mar 29, 2010 | 09:17 AM
Mus408's Avatar
BTW..What's with the two small resonators right behind the X-pipe?
Old Mar 29, 2010 | 09:22 AM
1chocophile's Avatar
+1. Wife has a 2003 Protege5. The filter is high enough that you're just about up to your elbow from below, but can't get to it from above. If the engine has even a little heat in it, you're toast. Pun intended. There are some aftermarket filter relocation kits out there, but I haven't looked into it too seriously...
Old Mar 29, 2010 | 09:54 AM
Overboost's Avatar
Someone has felt my pain! It truly is awful.
The newer 2.3 motors have the cartridge on the bottom, but it makes a heck of a mess when taking it out. I've thought about doing a spin-on conversion, but put it off when I decided to get rid of the car. I can suffer a few more oil changes.
Old Mar 29, 2010 | 10:35 AM
Ltngdrvr's Avatar
What about them? Part of Fords exhaust sound tuning.
I'm looking forward to hearing one with the rear mufflers deleted, ought to sound tough!
Old Mar 29, 2010 | 12:15 PM
My blood brother, with the brand on the right forearm to prove it!
Old Mar 29, 2010 | 03:07 PM
gremlin190's Avatar
Lol,
The Worst
The Nissan Pickup I had back in 97. You literally had to weave your arms thru rods and other stuff. Had to go to it from the bottom up and gl getting a wrench in there.
The best
My Dad's 2006 V6 Tundra has it right up top. It even has a catch area for anything that may leak out while you're removing it.
Old Mar 29, 2010 | 06:45 PM
Thanks, perfect responses.
Old Mar 29, 2010 | 08:10 PM
Skotty's Avatar
2008 Jeep Liberty oil filter is in a bad place too. I actually couldn't find it at first. Couldn't see it from the top or bottom. Had to feel around for it.
Old Mar 29, 2010 | 09:19 PM
Poisoned Pony's Avatar
ever seen the oil filter on the Mini's? Back of the engine, facing towards the firewall and not accessible from the top
dblhelx
Oct 6, 2015 08:08 PM
MustangConvert11
Sep 30, 2015 08:01 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
TripleBlack14
Sep 17, 2015 07:48 AM
