wheel spacer advice
Old Mar 19, 2013 | 06:57 PM
brandxj's Avatar
wheel spacer advice
so i want the wide stance look and can't afford new wheels. so i plan to get hubcentric wheel spacers. what size wheel spacer should i get to achieve the look on 235/50/18 wheels without rubbing issues? thanks
KCCO!!
Old Mar 19, 2013 | 07:44 PM
brandxj's Avatar
If I got a 1 inch spaer would I need to grind off some of the original studs to get the wheels on?
Old Mar 19, 2013 | 08:16 PM
ghigboss302's Avatar
I put wheel spacers on my 07 gt to give a more aggressive stance. 1" on front and
1.25" in rear. The front wheel studs did need to be shortened the rears I had no issues
Old Mar 19, 2013 | 08:45 PM
PaxtonShelby's Avatar
I would never run spacers of any kind on a car I planned to drive aggressively. Buy the right wheels to get the look you want.
Old Mar 19, 2013 | 09:06 PM
lsxjunkie's Avatar
This this this!
Old Mar 20, 2013 | 08:53 PM
JPMotorSport's Avatar
Exactly. Not to mention the increased wear on the axle/bearings/drivetrain/etc.
bad idea. Do it right w/ new tires/wheels. You'll be happier in the long run.
Old Mar 20, 2013 | 09:39 PM
lsxjunkie's Avatar
To be fair, lower offset wheels put the same strain on the axle and bearings. Regardless, I want my wheels to sit on the hub and bolt to the rotor, not a piece of milled aluminum.
Old Mar 21, 2013 | 08:04 AM
JeffL's Avatar
this. I've run spacers on lots of cars for years with no issues.
has anyone seen 10mm spacers with studs attached? The smallest I can find with studs is 15mm.
Old Mar 21, 2013 | 10:55 AM
ConeBoss's Avatar
Ditto, a good quality hub centric spacer is just fine and in some cases the only way to get the most tire under the car possible without rubbing.
Old Mar 22, 2013 | 09:16 AM
lsxjunkie's Avatar
I think 10mm may be too small to safely mount studs. The "spacers" that bolt to the car with their own studs are actually adaptors, originally used to allow people to both lower offset and change bolt pattern. I take extra issue with those.
Spacer
Adaptor
Old Mar 22, 2013 | 09:31 AM
JeffL's Avatar
with a 10mm spacer I will have to change the factory studs to the FRPP ones so they are longer, right? throwing that 10mm spacer on the factory wheel hub and studs won't give me enough lug thread?
Old Mar 22, 2013 | 10:33 AM
lsxjunkie's Avatar
Yes. Get ARPs and cut them down once you figure out how much of them you need.
Old Mar 22, 2013 | 01:21 PM
JeffL's Avatar
was thinking just opened ended lugs.
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
