Valve stem removal from wheel
Old May 12, 2013 | 04:06 PM
2012GTCS's Avatar
Well, its not a TPMS question but it kinda is lol. I've searched all over but nothing really related to this....
I have 4 wheels with no tires and I removed the TPMS sensors. I now just have the valve stem in the wheel. Is there anyway to possibly take that out or do they need to be replaced? I tried everything but there in a pretty dam tight. I've read that it states they should be replaced at tire change, but they're really only about 2000 miles old.
So, even if I give up on these and try to find new ones how/how easily do they go in?
Also, can anyone recommend a place to purchase just the valve stem replacements? I see like rock auto but not sure if its a cheapo type. That's really all that comes up when you search.
Here's a pic of the inside of what I'm talking about, seems impossible to remove. Thanks!
Old May 12, 2013 | 04:17 PM
Gabe's Avatar
New ones get installed from the back of the wheel - the side you're showing in the pic.
When a tech would remove one to throw it away, I've seen them use pliers and just pull on them from outside, but I think that was regular valve stems, not the ones with the metal stud on the back for the TPMS sensor.
If you have a tool like the one below you can try sticking it under the rubber part from the back and backing out the stem
Old May 12, 2013 | 04:31 PM
Ltngdrvr's Avatar
Why do you want to replace them?
If you are wanting to mount new tires on the wheels just go ahead, nothing wrong with that. You can even mount new sensors on those stems if you're putting them back on a Mustang with that style TPMS.
Old May 12, 2013 | 04:34 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
cut them. you dont want to reuse them. stop by a firestone and ask for some. im sure they would give you a set or only charge you a small bit.
Old May 12, 2013 | 05:29 PM
Ltngdrvr's Avatar
Why wouldn't you want to reuse them since they are not very old?
I could see replacing them if they were older.
Old May 12, 2013 | 05:35 PM
Gabe's Avatar
I re-used mine when I switched out the summer-only Pirellis for the all-season tires at 4200 miles
Now at 11,400 miles, no issues.
Old May 12, 2013 | 05:50 PM
Bear Eats King...
Bear ****s Bone
just seams like a hassle for such a cheap part. i just replace them
Old May 12, 2013 | 05:52 PM
Bear Eats King...
Bear ****s Bone
i guess i see differently lol. its a valve stem. cheap easy to find. autozone and all the shops have them. i dont feel like trying to worm them out for reuse
Old May 12, 2013 | 07:45 PM
Ltngdrvr's Avatar
Why take them out at all?
And the TPMS stems aren't cheapo like regular ones.
Old May 13, 2013 | 05:44 AM
Bear Eats King...
Bear ****s Bone
they can get old and leak. so they recommend replacing them every tire change.
2.99 aint cheap???
http://www.autozone.com/autozone/acc...er=358617_0_0_
Old May 13, 2013 | 06:29 AM
Stevedotmil's Avatar
Replacement of valve stems should be done at "Every tire change" which constitues much more mileage than the OP has on his stems. I would just leave them there.
Old May 13, 2013 | 06:31 AM
Ltngdrvr's Avatar
But the ones in question by the OP aren't old.
And I've never had any so old that they leaked, only issue I ever had with any valve stem was if it was damaged.
Old May 13, 2013 | 06:38 AM
Bear Eats King...
Bear ****s Bone
Correct. But he was asking about removing them. So i figured he didnt want then in the wheels for a reason. I said cut them out cause they are cheap.
Working in a primarily tire shop you see a bunch with valve stems leaking due to age
Old May 13, 2013 | 06:41 AM
2012GTCS's Avatar
Thanks for the replies.
The reason they are coming out is because my wheels were warrantied (CDC, great guys to deal with btw). So I am shipping mine back and have a new set ready. Hence why I was trying to swap them over. I just had no background on this stuff. Now I see that they are difficult to remove, I'll just get new ones.
I've seen those stems at auto stores etc, but was wondering if they were too cheap and I should stick to Ford ones, if they even make OE ones. Probably only sold with TPMS if I know Ford.
Old May 13, 2013 | 08:02 AM
LowDUB's Avatar
Well u need the correct ones so the sensors can screw into the bottom of it ford sells them separately
Old May 13, 2013 | 08:06 AM
Ltngdrvr's Avatar
You can get the new stems at parts stores like napa or carquest or oreillys, just have to make sure they are for the screw on TPMS sensors.
And, had we known the issue was to swap them over to new wheels then there wouldn't be any question about not reusing them.
I would still leave them in the wheels if you are sending them back, why worry about them if you're not using them any more?
Old May 13, 2013 | 08:24 AM
Bear Eats King...
Bear ****s Bone
Ford, chevy, and dodge all use the same valve stem mount. So the one i showed from autozone will work at 3 bucks a piece
Old May 13, 2013 | 09:53 AM
Good to know.
Old May 13, 2013 | 01:31 PM
2012GTCS's Avatar
Well that's how I worded the question. People assumed what I was/wasnt doing.
And that was the original question, if they were actually removable. If they were easily removed, I'd reuse them, which is what I was hoping to do. That way I wouldn't have to get new ones and could just have tires mounted right away instead going out and getting/ordering the stems.
Thanks for all the replies so far.
Old May 13, 2013 | 01:46 PM
Ltngdrvr's Avatar
If you're having a tire shop install them then they probably have the stems in stock.
hpb50
Sep 27, 2023 03:03 PM
lowblustang00
Sep 5, 2015 12:18 PM
tukatz
Aug 13, 2015 09:27 AM
nismos13s14
1994-2004 V-8
Jul 31, 2015 07:40 AM
LuiG31
Ecoboost
Jul 20, 2015 01:25 PM
