USB Playlists?
USB Playlists?
Can anyone tell me what format should be used for playlists on a USB flash drive? I plugged in a flash drive that I have been using for some time in my other car but the Sync/Nav system says "invalid playlist format". It's the same M3U format I've also been using on my Sansa MP3 player for years.
Does the system not like folders? The entries in the playlist file are just file names in the format /foldername/filename.mp3 with each entry on a separate line.
I had issues trying to play mp3's from a flash drive also. It would play some songs, but not others.
I don't know if there is copyright protection in the Sync or what. When I transferred the same files to my Sansa player and connected to the Sync, it worked fine.
I used MediaMonkey as well. Playlist didn't work at first, but I moved the playlists from the "Playlists" folder and put it in the roof folder, and then the playlists worked fine.
