Trying something different with my suspension (2012 SVTPP on 2014 GT Track)
Old May 18, 2013 | 12:46 AM
lsxjunkie's Avatar
So I picked up a set of 2012 SVTPP takeoffs for 375 shipped. The struts are assembled with OE GT500 Strut Mounts, so at least I have those if I'm really not happy with the suspension performance and want to go to aftermarket struts. I'm not really looking to lower the car as I drive all through NYC and the surrounding area quite a bit on roads that are so worn that a car on K springs would scrape constantly. These are slightly lower (11mm Front and 8mm Rear) than standard GT500 springs, but seeing as my car is a solid 100 or so lbs lighter than a GT500 in the front, the front of the car won't come down as much, which is fine. The car comes a bit too raked for me anyways. I'm mostly after the shock performance, as I find the GT Track/Brembo very underdamped, so if this doesn't do much to lower the car, I'm okay.
Anyhow, I'm bolting all this stuff in the morning. Pics to follow.
Old May 18, 2013 | 04:49 AM
wickedpony's Avatar
Cant wait to see how this turns out. I almost did the same thing, but I wanted more of a drop. I picked up a set of sportlines, just have to put them on now.
Old May 18, 2013 | 03:18 PM
lsxjunkie's Avatar
So I got it all installed today. I love the way it drives, I love the mild drop EDIT:CAR DID NOT DROP IN FRONT, I'm really happy with it all.
EXCEPT... something rubber is groaning when I turn the wheel. I can only hear it at idle and it gets louder if I've been braking heavily. I have no idea what it is. Maybe strut mount? Maybe endlink? You can't hear it outside the car but you can feel it in the fender. Something rubber is binding up and releasing when I spin the wheel.
DIAGNOSED: Pulled the strut mounts. The coil isolators were missing. The spring was just sitting on half of the lower section of the strut mount. This is how they looked when I pulled them out of the car.
Old May 18, 2013 | 04:41 PM
2013Trackpack's Avatar
On my 13 gt track I put the 2012 svtpp struts, shocks, springs, front sway, brembo brakes( I like the black better), mufflers, and wheels and tires. I'm really happy with mine.
Old May 18, 2013 | 07:55 PM
wickedpony's Avatar
Looks good, How much of a drop would you say this gave you?
Old May 18, 2013 | 08:07 PM
lsxjunkie's Avatar
A half an inch in the back I guess. I'm just pissed about the groaning noise, although it may be my fault for not torquing the strut mounts down properly. I figure the noise may be the spring spinning against the strut mount, although I don't know why the strut mount wouldn't spin first, seeing as the car is already on it and loaded up.
Old May 19, 2013 | 02:20 AM
Stevedotmil's Avatar
White lithium grease might have been a good idea as well.
Old May 19, 2013 | 08:31 PM
wickedpony's Avatar
Looks good, gave it a nice drop
Old May 19, 2013 | 08:49 PM
TheDivaDanielle's Avatar
I can't even see a drop at all, but to each his own.
Old May 19, 2013 | 08:58 PM
Five Oh Brian's Avatar
I see two "before" pics. Where's the "after" pic???
Old May 19, 2013 | 09:32 PM
lsxjunkie's Avatar
Redacted
Old May 23, 2013 | 11:52 PM
lsxjunkie's Avatar
So it turns out my strut groan was a result of Shelby American taking the upper spring perch out of the strut mounts and reusing it on the car these came off of. They then zipped the incomplete strut mounts back onto the struts and sold them. Womp. I ordered new strut mounts which raised the front of the car back up to factory height but killed that godawful noise. This is where I am now.
If I want to lower the car, I'll pick up a set of P springs. These shocks are designed to work with the L springs, which are an inch lower than these springs now, so there shouldn't be any problem with P springs. I have to do a little more research into the spring rates, but that's where we're at. The car handles great, rides a little rougher, but feels immensely more controlled all the way around.
Old May 24, 2013 | 09:09 AM
dmichaels's Avatar
Are the struts adjustable damping?
Old May 25, 2013 | 11:47 PM
lsxjunkie's Avatar
No. These are 2012s, not 2013s.
GT227
Jan 22, 2016 06:51 AM
70monte
Mar 26, 2015 10:07 PM
djstorm100
12
Jan 26, 2013 09:17 AM
Fintile
Oct 30, 2012 11:07 PM
ragz06
Apr 12, 2011 11:11 AM
