Are most struts from 05-14 the same?
Old Mar 24, 2015 | 09:36 AM
70monte's Avatar
The reason I'm asking is that I bought a set of slightly used struts off of Ebay from Shelbyauctions that were listed as 2014 Mustang GT struts.
The struts that I received also came with the springs and strut mounts. I noticed that the springs had one less coil than my factory 14 GT springs so I did a search of the Ford #'s on the struts and springs and they seem to come back as coming off of a 2007-2009 GT500.
I emailed Shelbyauctions back and they told me that all struts from 05-2014 with the exception of the 13-14 track pack cars are the same. I find this hard to believe so does anyone know for sure if this is true? Here are the numbers off of struts and springs if anyone has a good source to look these up.
7R3V-5310-JB-springs
7R3V-18045-GA-struts
Thanks, Wayne
Old Mar 24, 2015 | 02:42 PM
jp1seattle's Avatar
11-14 are different up top. They'll need GT500 mounts to work.
I think 07-14 GT500's are the same.
Old Mar 24, 2015 | 02:43 PM
jp1seattle's Avatar
Use the mounts they came with and you should be good to go!
Old Mar 24, 2015 | 04:24 PM
70monte's Avatar
Thanks for the replies. I guess as long as the actual strut is the same, I'm good to go. I won't use the spring that is on the assembly because I don't want my car any lower than it is. Thanks.
Wayne
Old Mar 26, 2015 | 04:57 PM
duff's Avatar
Just because it has one less coil, doesn't mean it will sit lower. In fact, it is likely just the opposite in this case. A gt500 front spring rate is greater than a GT front spring rate. It might actually raise the front of the car. I'd try it as is before disassembly of the strut and decide from there.
Old Mar 26, 2015 | 10:07 PM
70monte's Avatar
Ok, thanks.
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
dohc97
Sep 24, 2015 01:52 AM
