Transmission issue here (after 9 months no problems)
One thing i definately noticed about that clutch-tranny issue is that it doesn't like to shift at low rpm's. Once you're above 3500-4000 rpm it does shift a lot smoother.
Eorocobra, can you provide us with your work order details on what parts they used to fix your clutch.
I've had this issue 2 weeks ago, I was at a red light and revved my engine(4000-5000rpms) to please my buddies ears, the light turned green I put it in first, started going could not get it in second, clutch was stuck half way. Then went to the movies and pulled into a spot in second running low rpms and went to put it in reverse and my clutch was stuck in the middle again. So I am just waiting for it to happen again. Not sure if my build date was June, not sure where on the car to look for the build date either.
This is Deysha with Ford Customer Service. I think you should bring your vehicle in to your Ford dealer for diagnosis. Then, please message me with your dealer, mileage, VIN, and contact info so I can escalate this for you.
Deysha
I am still happy with the car and satisfied with the repair. I may be over reacting but I swear I hear random whining noises from the transmission. However no shifting or driving issues. My car was built in May 2010 around the 17th and sat for a few weeks at some ramp (ramp51 maybe) like many other cars. Perhaps Ramp51 is a quality control area. As I recall there was some issue that rectified at this location.
ssjbuu
8/28/15 08:55 AM
mustanglindsey
8/3/15 09:07 AM
