Tire pressure of 19" premium
Old Aug 2, 2010 | 05:28 PM
RedWings's Avatar
TPMS said i had a low tire so i checked the door sill to see the recommended pressure was. It says 32 but three of my tires read 38 and one was 18.
What are all you runnin'
EDIT: I did the readings while tires were cold
Old Aug 2, 2010 | 05:32 PM
Ltngdrvr's Avatar
Run what it says on the door unless you are racing.
Old Aug 2, 2010 | 07:04 PM
Adam's Avatar
Yep.
Old Aug 2, 2010 | 11:30 PM
Gene K's Avatar
On the 18's I like 38/35 F/R.
On the 19 (Shorter Sidewall) I would try 35/32 F/R.
The reason I run a little more pressure at the front is improved turn in. Even the rear was a touch soft at 32 psi. All pressures cold in the morning of course.
Old Aug 3, 2010 | 09:29 AM
Turboba6's Avatar
For Best Traction Off the Line, Straight Line of Course, 27PSI Rear on the 255/18's...
oldnjguy
Sep 10, 2015 02:39 PM
rick57
Sep 9, 2015 03:37 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
