Tested Ford Module Programming Application
Hey guys,
I still enjoy getting more knowledge about diagnostics & programming possibilities for the Mustang.
Yesterday I had some time left so I've tried the official Ford Module Programming application. I needed it anyway because my sync needs an update (TSB). To make a long story short, it wasn't impressive, read more after some general information:
What is it?
Its a software you can officially download after sign up. Its based on IDS but the only functionality is to update modules to the newest software version or program them.
Where do I get it?
Motorcraftservice.com
What does it cost?
The be able to use it u need to have a valid subscription. I purchased 3 days for 32 $.
What hardware do I need to program?
You need a SAE J2534 compatible device, examples are:
**J2534 Pass-thru Device Name Manufacturer *CarDAQ+ Drew Technologies, Inc.
*Mongoose PWM + FEPS/Can Drew Technologies, Inc.
*PassThru+XS Actia Corp
*Snap-On Pass Thru Pro II Snap-On
*2534 Global Programmer Blue Streak Electronics
*Universal Reprogrammer EASE Diagnostics
*FLASH2 All-Makes Reprogrammer CARDONE Industries
*Bosch Mastertech VCI Bosch Diagnostics
Usage and results:
The usage was pretty easy, just download & install the software. After that it will search for a compatible device and test it. Than you have to enter your subscription information into the program and you're ready to go.
I checked the PCM, ICM, ACM for online updates - all were up-to-date.
The Sync module was the only one I really needed the update but only this one showed me the message "Please initialize update using OASIS"![Mad](https://themustangsource.com/forums/images/smilies/mad.gif)
![Thumbsdown](https://themustangsource.com/forums/images/smilies/thumbsdown.gif)
![Nonono](https://themustangsource.com/forums/images/smilies/nonono.gif)
So yes it works and if you need to update your PCM its doing a good job but since some modules cant be updated without OASIS its useless for me because I cant get a OASIS account + its kind of ridicules since Ford offers it as an alternative for free mechanics but than ask you to go via OASIS![Screwy](https://themustangsource.com/forums/images/smilies/screwy.gif)
Hope that helps some people
What is it?
Where do I get it?
What does it cost?
![](https://www.motorcraftservice.com/vdirs/images/icon_external_link.gif)
Usage and results:
7/30/15 06:47 AM
