Sync 4.4 Update.
#423
I've tried multiple times. I get it to say it is updating then before the voice is even done it says failed. That there either isn't enough space or the update isn't for this product. I verified the software that shows on the website is the installed version on my car. I'm lost.
#424
Ford In-Vehicle Technology Rep
I'll shoot over a PM soon.
I see that you sent a PM; I'll respond shortly.
Shaay
#426
#427
Anyone try disconnecting the battery? i've done master resets and nothing but was thinking that might be a step farther.
#428
I've tried disconnecting the 15A fuse for SYNC, I've tried disconnecting the battery and I've tried Master Resets. I always get Installation Failed. You can go ahead and try for yourself, the results seems pretty unconsistent from one user to the other, so...
#429
This is a stupid problem to have. I just want it to default to bluetooth audio so I don't need to fiddle with the ***** as much
#430
![Confused18](https://themustangsource.com/forums/images/smilies/confused18.gif)
#431
I know my friend. A lot of us find it frustrating. It would be nice also to have a display of the song title instead of that bland "Bluetooth Audio" display. All this is available to random user being able to install the 4.4. update. Patience I guess is key for the others, so better get use to fiddle with the *****.![Confused18](https://themustangsource.com/forums/images/smilies/confused18.gif)
Apparently you haven't done the 4.4 update, because it displays track and artist information with that update. Why haven't you updated it?
And my system with the 4.4 update never fails to return to bluetooth audio every time I start the car. I have a feeling that a lot of people complaining about this didnt do the update correctly, so they are still on the old software.
#432
#433
#435
I scrolled up a bit and didn't see that in the thread. You obviously then have bad hardware on the SYNC/USB port side or your USB Drive.
#436
#437
I downloaded the two files from 4.4 to a fat32 USB stick. Only one file was a zip file (about 10 items I believe). Is that correct? For those of you that are having issues with the download in the car, does your Sync still work the way it did before you started? I do not want to lose my Sync (working fine now) just to get the song title in the display instead of it showing blue tooth audio.
#438
tucsondivots (4/18/16)
#439
