Sync 4.4 Update.
#241
The other lousy part I've found now is that my plugged-in iPod with about 3,000 songs on it will no longer fully index. I can play by artist and album but not by track anymore, which is ridiculous. Not thrilled with that but otherwise am happy with it.
#244
So I updated my sync to 4.4 last night. Few observations so far, when I select bluetooth as the source, it says unknown. When I select Mobile applications/Pandora, it shows the artist/song title, but I can not change the station. To change station, I had to quit Pandora on the phone, start it again, and change the station. Now on the car radio, it won't find Pandora in Mobile Application. I had to unpair/repair the phone before Pandora shows up again in Mobile Application.
Am I doing something wrong or am I missing a step in here?
#245
Hey DarrenGT
Here is the web site that you log into. It will let you know if and when you need to do a sync update.
https://owner.ford.com
#246
after the installation did you turn the car off completely and opened the driver door (to cut power to radio) then tried again? alot of things dont work properly until you cut the power off completely
#247
This update has been beast for me. I have a subscription to Beats Music and use Soundcloud and Milk Music regularly, and being able to see whats playing as opposed to having to turn my phone on is great. Also it seems the bluetooth quality has gotten better, but maybe thats my ears? And having the car automatically pick up bluetooth as the last source when i power the car back on saves me a whole lot of time and headaches.
#248
Did the update last night. Seemed like it could have went a lot quicker if all the steps were published. There were a few missing critical steps from the instuctions for my car. I assume that those on 4.2.x would all be similar, but took me a while to find the install application option. Once I got there it was a piece of cake.
Being in software development my opinion is that the install feedback could be much better. Kinda leaves you hanging after the reboot. Could at least tell you it is installing... Maybe there is a limited amount of space or memory or maybe they just did not care.
But anyway it went on without any problems and no issues so far.
#249
Being in software development, you should realize that this system is 6+ years old, and consists of several stacks stitched together, each written by a different company. I count at least Microsoft, Clarion, and Ford. I'm pretty sure the first two haven't touched the code in 6 years. Ever wonder why "4.4" is never displayed anywhere, and why there are at least 4 different screens showing version numbers that don't correlate with each other?
#250
Update Information
Still no update for me. I even got a phone call from a Ford representative that said it should be available 3 or 4 days ago. 2012 With the navigation screen. I think I am mostly caught up and looking forward to the BTST data, but can anyone with the navigation screen able to tell me if the backup camera boots any faster? That is probably the only thing I am jealous of on a MFT vehicle is it seems to boot as soon as you open the door and by the time you start and hit reverse it is almost instantaneous. Ours seems to have the ability as there is still power to the Sync unit when the car is off. If you hit the power button with the car off the screen powers on and the time is displayed for a few seconds and then it shuts off. I tried that the other day because that is how you put my wife's MFT car into accessory mode. Also another question I have is when you are on the phone and a text is received is there anyway to not clear the message from the phone until it is actually viewed in the car. It is easy to miss when you are on the phone and if you get out without getting off the phone it is still cleared from the phone even though the car never actually prompted the message. I promise I am appreciative of this update, but it is long overdue.
#251
#252
#253
Hello, new user here!
I recently just updated to 4.4 Sync Basic and I've run into an issue where if my phone (Samsung Note 3) is connected via Bluetooth and 911 Assist is set to OFF (either with or without reminder) that the Sync system keeps turning the center console on and off repeatedly until you either turn on your radio or disconnect the Bluetooth.
Is there a fix or capitulate to 911 ?
Thanks everyone....
#254
Please tell me that you have found a fix for your problem. I updated mine over the weekend and everything seemed to be going just fine then, but I only really got to test the bluetooth out tonight and this is exactly what is happening with mine.
2013 V6 Premium, MCA edition trying to connect to a Moto X 1st Gen (2013). Aside from not the best sound quality from the bluetooth and some random disconnects here and there, it worked just fine before the update.
-Phil
-Phil
I've tried pulling the Sync fuse, re-installed the 4.4 update and used different phones with the same result. If I leave Bluetooth disabled on the phone, Sync/center console does not exhibit this issue. This seems like a software bug that managed to get through the release patch, has anyone else observed this issue since updating?
The video below is exactly what is happening and the documentation of what does/doesn't trigger it. It seems like Sync is attempting to alert the driver that 911 Assist is set to off, but because all audio is off, the notification is cancelled and tries again over and over (the previous build would always play the notification even with the radio/AUX turned off fully.)
https://www.youtube.com/watch?v=UVCbDUOEU9U
What has been documented:
- If bluetooth is disabled, Sync runs fine.
- If the radio/AUX is left on, even if muted, the 911 Assist alert displays/plays correctly
- If bluetooth is enabled and the radio/AUX is left off, the 911 Assist goes through an on/off loop cycle that does not end.
- The On/Off cycle can be "broken" by turning on the radio/AUX.
- If you turn on the radio/AUX quick enough, the 911 Assist alert will display/play correctly.
#255
#256
-Phil
-Phil
#257
I haven't been able to find a fix sadly. I sent the IVT representative a message about it and this thread with the documentation, haven't heard anything back. The only "fix" that will prevent Sync from doing this is to leave your audio on before turning your car off (even if muted). It appears to be an issue where because the center console is turned off, when 911 Assist tries to notify you that it is turned off, the console turns it right off again.
#258
If 911 Assist is enabled, this will not occur.
#259
No Update For You!
Yep. I've Updated the car twice in the past from 4.0 to 4.0.2 and to 4.2.1.4 The IVT said the update is available for my vin and website has released the update to me as well. It got to the point where I guess they didn't believe I was competent enough to check the website properly and they asked for my login credentials to the website. They navigated to the update page only to find that it says I have the latest and greatest version of sync (@4.2.1.4). My issue was re-escalated and they advised me that they took a screen capture and sent it to the website development team. They also told me there are a few SUVs with the same issue, but it is primarily Mustangs and that it is not a unique issue. I'm still waiting to hear back at this time, but this issue has been in their hands now for 3 weeks today to release this update. If I had to guess I've spoken to at least 10 different people. Four in that last phone call alone, so it would appear they really are trying to figure it out.
#260
Figuring it out and getting a fix pushed are two totally different things. It may be months or never before we see a fix. When Ford first introduced Sync they would update it about every 90 days for stability and updated functionality. Obviously that has changed.
