Smokey start
Old Feb 22, 2015 | 12:06 PM
Dawgsfan's Avatar
Smokey start
Twice I have notice a smokey start after backing the car out of the garage. The first time I backed it out turned it off, went inside to grab a few things and 5-10 min returned and stated. Enough smoke to notice floated past the front. Yesterday pretty much the same thing happened, a couple weeks after the first time. Backed the car out and did somethings around the house and started it a couple hours later and got the smoke again. I'm guessing some oil is getting past the rings but I haven't noticed this any other time, driving or starting. When this has happened it has been on a level surface.
The car is pretty much stock engine wise, 2011 5.0, auto with about 60K miles. Any thoughts out there? Anyone else get this? Thanks in advance.
-Chris
Old Feb 22, 2015 | 02:12 PM
Getportfolio's Avatar
White smoke? Black smoke? Was it cold outside?
Old Feb 22, 2015 | 02:48 PM
MRGTX's Avatar
This was common with the 4.6L motors. My 2009 GT did this occasionally with fewer than 20,000 miles.
Keep a close eye on your oil consumption...likely this will only be a cosmetic issue but it needs to be monitored.
You're still close enough to your power train warranty that you may be able to get some help if there is a serious issue.
Old Feb 22, 2015 | 03:42 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Both my 08's would do that and I've seen my 500 do it too. Its only when you start them cold, let them run for a minute or two and shut them back off. Next time you crank it, puff of oil smoke comes out.
Old Feb 26, 2015 | 09:29 AM
FordService's Avatar
-Chris
Have you had this addressed by your Ford Dealer yet, Dawgsfan? Be sure to speak with your service manager, as he is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed.
You can schedule an appointment online here.
Deysha
09-gt/cs
Oct 15, 2015 10:03 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
