sirus radio issue
Old Jun 29, 2011 | 01:41 PM
rcm1802's Avatar
sirus radio issue
My sirus cuts out occasionally.Its Like when you plug head phones into a jack over and over again. Is anyone else haveing this problem. My dealer said it was the signal and there was nothing they could do. But I've had cm andsirus before and never has problem. Tell me what you think
Old Jun 29, 2011 | 01:56 PM
bones302's Avatar
your description is kind of vague. is this when you are moving? when it cuts out, are you under an overpass, or under a dense set of trees or in a canyon/valley?
FCMalie's Avatar
I have it happen as well, for me it is definitely a signal issue. It cuts out when I pull into my garage, or on some of the downtown roads in my home town with thick covering trees.
Old Jun 29, 2011 | 02:23 PM
freyke's Avatar
It's expected from time to time.
2.33Ghz to 2.34Ghz Downlink freq (5.1" Wavelength) is virtually line of sight (aka objects in the way will block the signal) espically given the size of the Sirius recv antenna on your car and the spacecraft being 24,000 miles out in space.
Also there are certain dead spots in the earth coverage from the spacecraft.
Old Jun 29, 2011 | 04:02 PM
AzPete's Avatar
Mine has done the same in the wide open spaces....on the last two Fords I had. Seems to be a Sirius problem as I ran the regular FM for a few days and no cutout. Try the regular radio and the CD to see if is limited to Sirius.
Old Jun 29, 2011 | 08:51 PM
TheReaper's Avatar
Sirius is some serious garbage.
Old Jun 30, 2011 | 12:16 AM
Swoope's Avatar
where were you. downtown charlotte? had you just gone under a bridge or flyover?
beers
Old Jun 30, 2011 | 12:17 AM
Swoope's Avatar
so xm is better?
what is your point.
beers
Old Jun 30, 2011 | 04:54 AM
rcm1802's Avatar
its in wide open spaces not in a downtown area or covered by trees. and it only does it on the sirius. so im guessing sirius attenna issue or sirius radio is just ****.
Old Jun 30, 2011 | 06:26 AM
freyke's Avatar
What % of time would you say the signal is dropping; 10%, 50%, >1%? Is it always in the same spot? Do you have a friend with a sirius equipped car - go to the same locations and see if you both experience the same drop-outs.
Old Jun 30, 2011 | 10:24 AM
TheReaper's Avatar
Originally Posted by Swoope
so xm is better?
what is your point.
beers
FM is better. The sound quality of Sirius is BAD. I had two other vehicles and did not renew it.
What's your point ?
Old Jul 5, 2011 | 02:50 PM
rcm1802's Avatar
So after driving the car from charlotte nc to dearborn mi I've come to the conclusion that its just sirius dead spots. It was in the same place every time. Ohh well thank s for all your help
Old Jul 5, 2011 | 08:05 PM
eliyarbrough's Avatar
Were I live, my Sirius works flawlessly. I live in a bad spot for any radio reception! So bad, in my 95 I had custom 4" antenna made. I only listened to CD's in it. I only listen to my Sirius now.
Old Jul 6, 2011 | 09:44 AM
bones302's Avatar
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
