RPM Lmiter: Info Needed
Old 5/21/10 | 03:05 PM
Old 5/21/10 | 03:27 PM
trane's Avatar
Originally Posted by 06GT
ROFL...u bastard
LOL!
Old 5/21/10 | 03:44 PM
bob's Avatar
bob
Originally Posted by fritzOSU03
Ok, I have a question that is kind of related to this topic. It's been posted that the 5.0 is electronically limited to 146 MPH, IIRC. Does anyone know what the V6, V6 202A, and V6 203A are limited to?
Everything I've read says 112 mph (I haven't heard about differing speed limiters other than the V6 112, GT 147, GT500 155).
Pretty easy to validate IMO, if the car is set to 112 mph it should happen a few ticks after the car's trap speed in the 1/4.
A GPS would be handy to verify the actual speed - My reads 2 mph fast.
Old 5/21/10 | 03:45 PM
Ministang's Avatar
The V6 that Car and Driver tested, which was a loaded V6 with manual transmission and the performance package was governor limited to 113 mph. Seems hard to believe, but hopefully that will change with actual production V6 cars, at least with the performance package option, as that option won't be available to consumers until Job 2 build, yet most of the magazines are getting V6's with that package to test.
Old 5/21/10 | 03:46 PM
trane's Avatar
Originally Posted by bob
Everything I've read says 112 mph (I haven't heard about differing speed limiters).
I'm pretty sure the 112 MPH is "topped out" for the 2010 V6. We've seen dyno pulls for the 5.0 that appear to have exceeded 150 MPH. The 2011 V6 should do at least 140.
Old 5/21/10 | 04:27 PM
Bert's Avatar
Anybody know what the top speed governor is on the 2010 GT?
Just curious, I doubt I'll every get anywhere close . . . though it would be fun to try . . .
Edit - found it -- Top Speed = 149, governor limited, manufacturer's claim, according to Car and Driver 2010 comparo . . . . hmmm, where can I find a closed course to test out that manufacturer's claim . . .
Old 5/21/10 | 04:58 PM
fritzOSU03's Avatar
Can the speed limiter be easily removed? I'd image all I'd need is a tune to disable it. I agree, 112 MPH will come and go in no time for this 3.7 V6.
Old 5/22/10 | 06:33 AM
bob's Avatar
bob
A tuner can disable the function, I think all the popular tuners have it as part of thier accessible functions (except for the FRPP ProCal II).
Speaking of tuners and a recent article I read on the A6 V6 Mustang, I bet recalibrating the trans (unless the article was completely misleading) along with the minor bump im power will yield some intersting results. The article complained that the AT in the V6 car seemed hesitant to downshift compared to the AT in the V6 Camaro, as if Ford in its quest to get 31 mpg programed the tranmission to hold it in a higher gear longer.
Could be bunk as I'm unfamiliar with Ford's automatic transmissions? Do they have an adaptive calibration to some extent that will alter the shift schedule over time based on the driver's habits?
Old 5/22/10 | 09:30 PM
David Young's Avatar
I read somewhere with the properly rated (W?) tires the 2011 V-6 and G.T. were both limited to 149 m.p.h.
Old 5/24/10 | 03:15 AM
Slims00ls1z28's Avatar
Originally Posted by Ltngdrvr
I wouldn't put a lot of faith in the accuracy of the stock tach if that is what you are going by.
I would go with this. After I got the Z tuned and the limiter reset to 6800 anytime I romped it it seemed like the limiter cut off at like 6500 or so yet if I do like you said and bring it up slower then nailed it, it would hit the 6800. When data logged even though the factory tach didn't reach 6800 the car actually was hitting it.
Old 5/24/10 | 07:08 AM
assasinator's Avatar
you cannot go by the factory tach. it is cutting out below 7k, but the factory tach is still for reference. if you ever watch a dyno pull in your car the 'real' rpms will be read by the induction pick-up. also the factory tune peaks at 6500. a change in tune and exhaust should keep the power climbing. as much as i wanna just go out and get a complete exhaust, there is no proof that the few available actually work.
Ecostang
11/3/22 09:50 PM
00StangVert
1994-2004 V-6
9/11/15 01:08 PM
ClayP
8/3/15 10:00 PM
09-gt/cs
05-09 Exterior Modifications
8/2/15 11:08 AM
goocher625
1994-2004 V-8
7/15/15 09:08 AM
