Rim/tire size input needed, please
#141
I figured I'd try not coating it... And seeing how that goes. Since I never get it dirty other than dust, it cleans up easy anyways.
#142
Awwww man It looks like a monster truck now. I am probably the only one on this site that isn't a fan of these wheels. Sorry man . And it breaks my heart to say it, because i have had a crush on Marilyn for a long time now. When it comes down to it though, all that matters is that you like it. Glad to see that you are happy with it.
#143
Monster truck? Seriously? I don’t think so at all. From a practicality standpoint there has to be a little clearance between the tire and fender skirt.
I think it looks nice Burton! The only thing I would add is Roush front and side splitters. They give the car a more aggressive look and the illusion of being even lower to the ground. The side benefit is the side splitters help keep the trash off the sides of the car… Win-win in my mind.
John
John
#144
Kidding! No problem at all, no offense taken. Marilyn just happens to be gradually morphing into that aggressive, in your face lady. She just has REALLY high heels now. LOL.
As you know, "looks" are the most subjective of them all, and people will like them, and people will hate them. That's A-ok. However, as to the "monster truck" theme, I would assume that coencides with the 4x4 look right? Usually that is a result of the car's stock suspension, ergo the gap between the tire and fender, getting magnified (optically) due to the larger rim. In my case, I am lowered on K-springs (1.5" in the rear), so I would assume/hope that the 4x4/monster truck look doesn't apply to me . But then again, if you see it, I will defer to "personal preference".
I still love ya bro
John
John
But yes, thanks for the props on the new "look". I love those rims and ultra wide tires in the rear
#145
LOL... Sean... Notice how I will now refer to you as the wrong-spelling Shawn
I still love ya bro
I still love ya bro
#146
the golden question is -- can I fit 315's?
same springs, will have same wheels as Z to 5. I've been talking about switching to the Niche's for a while.
Got the fiancee's approval that next year I keep the Torq Thrusts for winter/**** weather, and run the Niche Milans in the summer (with taller tires, to save the car from bent wheels, as I'm about to replace a Torq-Thrust that is bent this week.)
Currently running a 255/35 295/30 Toyo Proxes 4-Plus combo on 20's w/ bad offsets. 34mm front, 32mm rear and the rears rub on my lowered car, on big bumps.
So i want to run 275/35's up front and 315/35 Nitto Invos on the Niches. Would they fit?
#148
#150
Yeah from what I heard and discussed with several owners with similar setups, as well as the "experts" from the vendors galore, according to them 305 35 20s on 20x10s shouldn't rub, particularly with nittos since they're the narrowest 305s. Also this is with K springs. So I hope they don't. If they do rub some, oh well... I don't drag or track it, so hopefully not.
#152
Here's a fair question to those of you out there:
If you are running 20" tires, and 305 wide, and are lowered, do you encounter any rubbing issues at all? What is your rear offset?
I will confirm again with my vendor today... I know I asked that before but now you guys are making me double check. Lol
#154
I have a question hopefully someone can help me. I want to buy a set of 20" forgestars they're 20x9 35mm offset fronts 20x10.5 40mm offset rears. Will these fit my 2011 mustang? I'm thinking they will stick out a little but that my guess? Can anybody help me
#155
Here's a fair question to those of you out there: If you are running 20" tires, and 305 wide, and are lowered, do you encounter any rubbing issues at all? What is your rear offset? I will confirm again with my vendor today... I know I asked that before but now you guys are making me double check. Lol
Better experts can chime in here... But from what I've seen and ran across during my research, with a 40mm offset and 10.5s you should be sticking out a tad more than mine. Not too much, but I prefer flush.
#157
Correct the difference would be approx. a 1/4 inch. Offset is very important when it comes to proper fitment to little and the wheels stick out, too much and there set deeper in the wheel well.
Also want to point out that Z's wheels sit pretty flush but with his larger 305 tires they appear to sit slightly outside the edge of the wheel well. A smaller 295 would likely leave the wheel more flush or even slightly inside the edge of the wheel well. Nothing wrong with either one here, it all comes down to personal preference.
#158
Correct the difference would be approx. a 1/4 inch. Offset is very important when it comes to proper fitment to little and the wheels stick out, too much and there set deeper in the wheel well. Also want to point out that Z's wheels sit pretty flush but with his larger 305 tires they appear to sit slightly outside the edge of the wheel well. A smaller 295 would likely leave the wheel more flush or even slightly inside the edge of the wheel well. Nothing wrong with either one here, it all comes down to personal preference.
#159
Rim curbing will never happen on your 305s. My 275s, I tilt the side mirrors and park 6" or more from the curb. My wheels on its side are higher than the tire.
#160
