Remote start issues
Old Jul 5, 2011 | 08:18 PM
JohnNy5126's Avatar
Remote start issues
Pressing the key fob to start the engine remotely will result in a chirp then the engine starts after 5 seconds, the engine shuts off. When I press the button again, the horn chirps 3 times and the engine won't start. I understand that 3 chirps mean that a door is opened, but none are. Any ideas?
Old Jul 5, 2011 | 08:30 PM
TheReaper's Avatar
Why did you need remote start ?
Old Jul 5, 2011 | 08:49 PM
xlover's Avatar
take it to the dealer
Old Jul 5, 2011 | 09:48 PM
JohnNy5126's Avatar
Well, thanks anyway. I figured someone had an idea so I can avoid going to the dealer. And the reasons I got it was because I wanted it.
Old Jul 5, 2011 | 10:23 PM
SoFlo Mustang's Avatar
sorry no one could help you haha. pitiful replies :P
Old Jul 5, 2011 | 10:39 PM
Adam's Avatar
Remote start is cool. If it's hot outside you can start it a few minutes ahead of time so that it's not blistering hot when you open the door. Likewise in cold climates. Works better if your vehicle is equipped with climate control.
Old Jul 6, 2011 | 07:37 AM
JohnNy5126's Avatar
Sure was....
Old Jul 6, 2011 | 08:03 AM
way2qk4u2c's Avatar
theres 2 ways a remote starter works
1 by seeing voltage
2 by rpm signal
If yours is not seeing the right rpm signal or the right voltage the remote starter will shut down- and when you try to use it again it will fail because the system shut down improperly and senses a false reading from one of the inputs.
Its possible that one of your inputs to the remote starter has been broken and would need to be serviced by the dealer or whoever installed it.
There is alot of inputs for the remote starter to work properly. If it doesnt see all of them it will shut the system down like your experiencing. Could be a faulty hood pin- neutral switch- brake switch etc.
Old Jul 6, 2011 | 05:26 PM
JohnNy5126's Avatar
1 by seeing voltage
2 by rpm signal
The car chirps 3 times which the manual says means a door is open.
Old Jul 6, 2011 | 10:22 PM
TheReaper's Avatar
Cool is not good enough.
Old Jul 6, 2011 | 10:24 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
In that case, I'd start with checking that switch and how it connects to the remote start system to tell it the door is open or closed.
Mpaps
Oct 11, 2017 08:06 PM
Fords4Ever
Oct 30, 2015 09:07 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
fredovega
Which is Better
Sep 3, 2015 07:20 PM
