Ramp Suggestions
Ramp Suggestions
Would someone please recommend a ramp brand? I would like to be able to ramp all four wheels at the same time so they need to be able to fit under the body just ahead of the rear tires. I've been letting others do my maintenance for the last 6 years, but not with this one.
I just ordered a yesterday. Wound up with the 87inch hd versions from reverse logic. My car is lowered so I needed the extra clearance. You'll need the roll ups as well if you want all 4 wheels in the air. Supposedly gives you 10 inches of space under the car. You get what you pay for. I have the cheap rhino ramps. They slide easily and you need to stack 2x4 to add some clearance. For me it wasn't worth taking a chance and damaging the front bumper
To each his own. My car is lowered so it's a process of two different jacks and driving up on planks. Total pain. Plus for quick oil changes, exhaust, and suspension work these can't beat ramps. I have 3 different cars all low so it was worth the investment
I used to go through the same PITA when working under the car and finally decided on a set of 56" 2 piece race ramps. I will never go back to floor jacks.
They weight only 10lbs each and yet are so strong. Perfect for lowered cars.
Feel so much secure while under the car now.
They're more expensive than the other brand x, but worth every penny IMO.
^^^this 1000 times.....
There's a yardstick test on the race ramp site where it shows you need a min of 7.25 on an incline. My mustang is lowered and I had 8.5. The only difference between the two lengths is the height 8 vs 10 and the width is 10 vs I believe 14. Clearance driving up is the same. I ended up with the 87 inch which gives you about 2.25 more inches of clearance just to be sure. I bought the 2 piece so super easy to store or hang up. Wanted a lift but with a small one car garage it was not an option.
You can use their tire cribs to put the rear tires up. Yes, they're a bit more money, but they are just about the 'be all end all' of ramps.
I've got a set of the Rhino Ramps from Autozone, and they worked on a stock height, no Boss splitter Mustang, now they're useless.
So happy with my 2 piece race ramps .
