Oil Pressure
Oil Pressure
I took my car to the dealer to have my first oil change about a month ago. They charged me an arm and a leg because "the 5.0 needs a lot more oil."
Well my oil pressure meter has been sitting a good bit above the halfway mark ever since.
Is this normal?
Is this normal?
Your GT takes 8 quarts of full synthetic, so yes, the oil changes can be expensive, depending on your dealer. For something so simple and gratifying, it's something to consider doing yourself, even if you aren't 'mechanically inclined'. The money saved on doing it yourself will pay for the tools, floor jack, jack stands, drain pain, funnel, and flexible funnel.
Plus you have the satisfaction of knowing it was done right!! Unless you aren't capable of doing it (live in apartment, physical issues, etc...), then you are at the mercy of a trusted service provider. Avoid the 'express oil' franchises at all costs, the internet is full of horror stories about those asshats...
Not sure if it's actually cheaper to do it myself... I'll run the math in a few thousand miles.
Dipstick checks out OK. I didn't notice the oil pressure being above midway before though.
Thanks for the reassurance.
If you're referring to the oil gauge between the tach and speedo, it doesn't give an accurate reading of oil pressure. It will display in the middle (or slightly above) if the sensor is between the normal thresholds, and will shift all of the way to either side if above or below those thresholds. It's closer to a dummy light than a gauge.
Still cost me 70$.
I grew up with a few guys who're now excellent mechanics but they just refer their customers to one lube joint or another for oil changes. It's hard to compete with companies who buy oil by the barrel (bulk price) and pay someone $10/hr to do it with idiot proof machines.
