Oil change ?
Old Dec 27, 2014 | 12:59 PM
Kestral's Avatar
Oil change ?
Since I bought my 2013 GT this past summer I have had the dealer change my oil twice. The slips both times says they put in 8 quarts of 5w20 although when I check it right away it reads down on the stick not quite half way down on the hash marks is this correct for 8 quart fill or should it be all the way up to the top of the hash marks on the dip stick?
Old Dec 27, 2014 | 01:07 PM
dmichaels's Avatar
Oil cold? Hot? Engine running? Off?
It's likely fine, how many miles are on the current oil? Some Coyotes burn a bit of oil.
Old Dec 27, 2014 | 01:12 PM
Kestral's Avatar
Cold or slightly warm... after sitting for several hrs... the dealer is right down the street so when I get home I park it for a while then check it.
Old Dec 27, 2014 | 02:15 PM
Trumpetlon's Avatar
You're fine. It should be about half way up between the lines on the dip stick after the oil change.
Old Jan 2, 2015 | 04:09 PM
2011 Kona Blue's Avatar
Even if someone uses a fully synthetic oil does it still burn some oil??????
Old Jan 3, 2015 | 02:42 PM
70monte's Avatar
I would say yes because even though I don't have personal experience with running fully synthetic in the Ford 5.0, I did used to run fully synthetic Mobil 1 in my 98 chevy truck with the 5.7L V8 and this truck used more oil when running the Mobil 1 than it did with regular conventional oil. I eventually quit using Mobil 1 and went back to a conventional and my oil consumption went down.
Synthetic oils have their place but they are not the end all, be all of oil. I have never read or heard of any study that proves that a fully synthetic oil will make an engine last longer than a conventional oil.
I think even the taxi cab tests that Consumer Reports did in the 90's came back inconclusive on the comparison between the two.
Wayne
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
