Official 2013 part retrofit thread
#263
MOTM Committee Member
#265
Is that from American Muscle or what? Ok I just saw the other thread you posted this in, looks like it is AM.
#266
#268
So i swapped my rear brakes to the GT500 ones. It works, couple of minor modifications necessary. I wrote instructions and have the complete kit on ebay, if anyone just wants to do the same without looking for all the parts and finding out what needs to be modified by themselves. This is how it looks (pic).
I also installed the 2013 HIDs, other than creating a new headlight connector and some custom wiring, as well as an additional bracket to support the grill, it works flawlessly.
LEXiiON
LEXiiON
#269
for the rears, it's simply a change to the rear caliper bracket, and installing the larger rotor though. it's not a major full on change. even uses the same calipers.
#270
Well, that is correct. But why do you think Ford has different part numbers for the caliper on the 2013GT500 ? There is a reason for this.... that's why i said minor modifications...
#272
I'm interested if you can provide details on the rear brake swap. I was under the impression that you needed to pull the axle to replace the caliper brackets. Also, do you have any issues with ABS being sensitive?
#273
Yes, you have to remove the axles to replace the bracket. I took the chance and upgraded my diff-cover at the same time. The process is easy, it just requires some time and man, that diff fluid stinks
No ABS issues. I don't expect any, as the sensor picks up the signal at the axle and other than the radius of the disc, nothing else changes. Also, the brake lines work absolutely fine with the different location of the caliper.
LEXiiON
LEXiiON
#274
LEXiiON
LEXiiON
#275
Anyone ever figure out if the cluster was swappable?
I have a 2013 instrument cluster in my 2012 now. It does indeed work, but there are some things that are not working, such as track apps, some of the digital gauges, and teh cruise control. Working on this problem now with dmhines.
Thread is here:
https://themustangsource.com/f803/13...14651/index18/
#276
What is the bracket for? I can't make sense out of these photos. 2013 headlights are the same dimensions. The fogs are considerable bigger with all the heatsink out back to cool the high temp HID fogs.
thanks..jw
thanks..jw
#277
Hi, the Headlights are the same shape, all the mounting points fit, but due to the different front bumper of the 2013, the mounting points from the 2010-2012 headlights as marked in the picture are missing. So i needed to create two small bracket to mount the top of the grill. Easy job, took less than 30 minutes. I haven't touched the fogs, one of the folks in our local Stang group has some due to a grill conversion, so maybe i will try that, too.
Hope this helps,
LEXiiON
Hope this helps,
LEXiiON
#278
Hope this helps,
LEXiiON
Hope this helps,
LEXiiON
