Official 2013 part retrofit thread
Old Nov 20, 2011 | 05:18 AM
Overboost's Avatar
Guys,
The purpose of this thread is to gauge interest and find out what parts from the '13 models everyone wants to put on their '10-12 cars. Obviously, there's a bit of time to wait before the resources will be made available, but my goal for this thread is to allow it to serve as a hub for all of this discussion. I will keep the first post updated with a listing of requests, and as things are deemed possible and/or completed, link to those threads.
Exterior:
-Rear taillamps & decklid blackout panel
-Heated side mirrors & pony projection lamps
-LED fog lights from '13 GT
-front end conversion (any style, includes hood)
-GT500 quad exhaust
-Headlamps
-GT/Boss hood vents
Interior:
-4.2" LCD display in gauges
-Recaro seats
Engine/Drivetrain:
-Cobra Jet intake
-Race/Track pack parts (Torsen, radiator, oil cooler)
-GT500 differential cooler
-GT500 Brembo 6-piston brakes
Suspension:
-GT500 Performance Pack electronically adjustable shocks/struts
NOTE: Anyone that can provide technical information, such as drawings, part numbers, etc. would be greatly appreciated!
Old Nov 20, 2011 | 07:59 AM
montreal ponies's Avatar
I'm interested in retrofitting that 8hp bump to my 11' .
Old Nov 20, 2011 | 08:24 AM
Nocturnal'14's Avatar
Hood from GT/Boss
Lower Front Bumper from v6 (w/fog lights)
California Special Grille
Old Nov 20, 2011 | 08:28 AM
Cyberalized's Avatar
Did a quick Photoshop of a 2013 decklid panel on a Super Snake with painted rear diffuser. I know this panel will grow on me...
Old Nov 20, 2011 | 09:09 AM
Overboost's Avatar
Originally Posted by Uin2it
Hood from GT/Boss
Not really sure what you mean here...a grille swap from '13 requires the entire front clip, including hood. Is that what you're referring to?
Old Nov 20, 2011 | 09:35 AM
linelock's Avatar
I'm interested in the electronically adjusted struts/shocks from the gt500.
Old Nov 20, 2011 | 10:01 AM
Thomas S's Avatar
I'm interested in Recaros(which should be easy) and Track Apps(not so much).
Old Nov 20, 2011 | 10:06 AM
CaptDistraction's Avatar
recaros, maybe the GT500 brakes (though the brembos are already pretty sufficient), torsen, some boss bits, and not sure if anything else (unless they have revised oil cooling, etc)
Overboost's Avatar
I knew someone would mention the LCD display in the gauges. Adding them to the list.
Old Nov 20, 2011 | 10:18 AM
xlover's Avatar
For the taillights wouldnt you have to replace the rear facia as well. Now that the kink is gone it would leave a gap where the kink in the 10-12 taillights was.
Old Nov 20, 2011 | 10:25 AM
Overboost's Avatar
That's what it looks like so far. It makes sense to change the bottom edge of the lamp at the refresh, since they changed the rear fascia as well. Probably one of the cheaper things to change. You'll need new harnesses for each lamp as well, and we don't know how the lamps are controlled. If it's not using a controller on the harness, then chances are the PCM controls it, and renders the retrofit **** near impossible. Still a lot to learn between now and release.
Old Nov 20, 2011 | 12:15 PM
m4reapr's Avatar
another thing to think about if the rear fascia is changed is that the lower edges are painted where the side splitters and front lower are still black plastic, for continuity everything would need to be painted or at least a good looking mix and match.
Old Nov 20, 2011 | 12:40 PM
HizliBullet's Avatar
I want the taillights without changing the bumper (assume I got my 2012 gt before end of the world)
Old Nov 20, 2011 | 12:52 PM
Overboost's Avatar
I've considered that as well. For those of us with unique colors to the '10-12 range, getting side skirts might be expensive to complete the look.
Don't think it's gonna happen.
Old Nov 21, 2011 | 12:12 AM
stangfoeva's Avatar
MOTM Committee Member
If I could get the track apps I would be a happy man, and the projection side mirrors for show
Old Nov 21, 2011 | 12:35 AM
2012 Black 5.0's Avatar
GT500 quad exhaust rear diffuser.
Old Nov 21, 2011 | 06:35 AM
Boomer's Avatar
You'll need more than just a tune ... :P
Old Nov 21, 2011 | 07:25 AM
correct....but I do not like the GT front grille, GT/CS looks much better. and the GT & CS do not have the lower fog lights which I want, hence the v6 front bumper request.
Looking to do a full front end conversion perhaps in the future.
Old Nov 21, 2011 | 07:58 AM
BlackMamba03's Avatar
Old Nov 21, 2011 | 08:05 AM
Hytek's Avatar
If making the retrofit for the guages and track apps isn't possible, then I would love for it to be an app version for Android or iPhone. There already is something similar with Bluetooth ODBII connectivity, I don't see why it couldn't be done.
