New supercharger option for the 5.0
Old Jan 22, 2011 | 07:43 PM
Ltngdrvr's Avatar
SHM, Sean Hyland Motorsports has a new TVS Eaton supercharger kit out.
605 HP at 7 psi, 515 RWHP, $5995.
http://www.seanhylandmotorsport.com/...1-mustang-5-0/
Old Jan 22, 2011 | 09:00 PM
YSUsteven's Avatar
That looks great.
But I am still trying to learn how to handle the 412 that I have. I just couldn't use 605, yet...
Old Jan 22, 2011 | 09:08 PM
m4a1mustang's Avatar
Nice!
Old Jan 22, 2011 | 10:17 PM
SteveRacer's Avatar
Sounds like a nice kit. It was also interesting to read about the 5.0’s internals.
Old Jan 23, 2011 | 12:51 AM
Big Poppa's Avatar
You could give some older Cobras a run for the money with this thing.
Old Jan 23, 2011 | 01:19 AM
Dragonacc's Avatar
This was actually the first kit out on the market if I'm not mistaken. I've seen it posted else where before a long time ago.
Seems like a pretty good kit for the price. But I think I would get a centri blower if I was going the SC route on these cars.
Old Jan 23, 2011 | 01:30 AM
rick0202's Avatar
wait a minute
if this is true
"The stock engine has forged PM rods, with HD 12 point rod bolts. The rods are beefier than the 4.6 3V rods, and were designed to operate at higher rpm’s.
The stock cast pistons have oil jets spraying cooling oil on the underside, providing better durability for extended high rpm engine speeds. The piston pin is a lightweight taper wall design, for minimum flex at high rpm.
The 5.0 arrives with a very high quality forged steel crankshaft standard, capable of supporting large power levels."
Then all they did for the Boss was get rid of the oil jets and put in forged pistons?
Old Jan 23, 2011 | 08:41 AM
Knight's Avatar
Needs to be more Astony
515rwhp is only around 585 flywheel hp. sucks seeing companies fudge numbers like that.
Old Jan 23, 2011 | 09:33 AM
YSUsteven's Avatar
Originally Posted by rick0202
if this is true
The Boss does not have a substantial power differance (412 vs. 440) so they did not need to do significant upgrades to the internals.
They did however rework the intake and cams, which is what yeilds power gains in the real world.
Old Jan 23, 2011 | 10:00 AM
Tony Alonso's Avatar
I believe this supercharger is on the MRT Predator.
Old Jan 23, 2011 | 05:15 PM
MustangGTPilot's Avatar
No the figures are right generally say 15% loss at the real wheels from flywheel so 605 - 15% = 514.25 hp
Old Jan 23, 2011 | 05:31 PM
5 DOT 0's Avatar
The Boss has 444 hp with sinter forged rods, forged pistons, sodium filled valves, and CNC'd heads along with a few other goodies so it's also capable of supporting more hp. The Boss will rev to 8,000 rpm but was held to 7,500 so it will last longer. Both engines should be able to support more hp.
Old Jan 23, 2011 | 06:07 PM
MARZ's Avatar
Swamp Donkey Aficionado
Yeah, this kit has been out for awhile, apparently. According to a couple posts in this thread below, Canadian tuner SHM has a bad reputation. I honestly don't know who or what to believe, so take it for what it is.
https://themustangsource.com/f800/wh...hyland-485186/
Old Jan 24, 2011 | 12:29 AM
rick0202's Avatar
thanks
So better rods and forged pistons. Why did they get rid of the oil spray? would that not add durability?
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
