Notices
Sponsored By:
Sponsored By:
lowered my '11 today
Old 11/29/10, 03:26 PM
Dreamtheory's Avatar
^ thanks everyone, I'm loving it now. I'm also glad i choose the 1.5" drop instead of the 2+" seeing as this is my daily driver
here are some more pic's =) they are not the best quality, I took them with my cell phone (Droid 2)
Old 11/29/10, 04:42 PM
Adam's Avatar
Originally Posted by Dreamtheory
Is that the car in the Ford YouTube videos? Same owner?
Old 11/29/10, 04:44 PM
The 2010 GT with the horse paint job along the side? yes, that's Daniel's car, and yes he is still the same owner. He rides with us at every cruise, event, and show. Real cool dude he was also one of TruFibers car for SEMA this year
Old 11/29/10, 04:52 PM
newpony's Avatar
Dylan your car looks fantastic!!!
I was thinking dropping mine an 1" but after seen yours I may go 1.5". Can you tell me how much ground clearance you have upfront?
Old 11/29/10, 05:06 PM
thanks!!! =)
definitely do with the 1.5" drop, the clearance is about 4.5"-5" now
Old 11/29/10, 05:37 PM
StGry11's Avatar
If you don't mind a quick question, did you add an adjustable panhard bar? I'm curious if it's needed for a 1.5" drop.
Old 11/30/10, 11:58 AM
fritzOSU03's Avatar
DT, I'm curious about this also.
Another thing I was wondering about is the quote below from the FRPP site.
Fits 2011 Mustang GT Coupe when used with M-18183-A upper strut mounts and M-18000-A Dampers
It says that the 1.5" drop springs require their upper strut mounts and their shocks to be compatible with the 2011 models. Did you actually need these parts or is FRPP trying sell more pieces?
Old 11/30/10, 12:26 PM
no sir i did not
The 1.5" drop worked out perfectly with just the springs, all the rest is still stock. FRPP must be trying to sell more parts or are just not fully aware.
Old 11/30/10, 03:12 PM
fritzOSU03's Avatar
no sir i did not
Thanks for the info. Is your rear axle noticeably offset without the panhard bar? I'd think it would be offset by about an inch or so but I'm no expert.
Old 12/1/10, 11:15 AM
Modshack's Avatar
Dupe...sorry!
Old 12/1/10, 11:16 AM
Modshack's Avatar
Measure it and I'll bet it's off. Mine was by 3/8" at a 1" drop. Likely your toe and front camber are out of spec too. I now have a Watts link installed, so no axle shift at all...
and fixed the front with toe adjustment and Camber bolts.
Old 12/1/10, 12:03 PM
sam strano's Avatar
If you don't change struts, then you don't need to change mounts. *IF* you only change to lowering springs, then you absolutely do not need the mounts. If you change struts, then it would mean you need to change mounts as there are no aftermarket units at this time compatible with the 2011 strut mounts.
They are saying it's 'required' because you SHOULD be upgrading the dampers when you put lowering springs on just because the stock stuff isn't meant to deal with lower, stiffer springs. And if you change struts, then you must also change mounts.
Old 12/1/10, 12:18 PM
fritzOSU03's Avatar
As usual, you're the man Sam. Thanks for the info.
Old 12/1/10, 12:21 PM
Modshack's Avatar
Here's a pic of the differences...2011 on the bottom, old style on top:
Old 12/1/10, 08:27 PM
KillerGT's Avatar
The stance and the wheels look great. I have always been a fan the mrr gt1 wheels.
kponypower
6/17/20 07:17 AM
Gill5oh
10/6/17 10:50 PM
PonyMuscletang13
9/29/15 09:40 AM
Evil_Capri
9/25/15 12:56 PM
lysingerjj
9/9/15 07:56 PM
Quick Reply: lowered my '11 today
