Instrument Panel Reflection on Windshield?
In my 2013 GT/CS, the tachometer and speedometer reflect on the windshield at night. I'm not sure what is causing the reflection. Does any one else have this problem? Any solution? Any difference for those of you with windshield tint?
Try putting your hand in front of the reflection near the windshield and move your hand around until the image goes away. It is reflecting off of something in front of the actual gages. Notice the reflections are not level with each other, one lower than the other?
Guess Ford is half way there to a H.U.D...
Doesn't look like mule testing was done at night.
We'll something to not look forward to when I get mine...soon.
If you put your hand over steering column, does that block the light?
I just sat in my garage trying to figure it out, and now I'm even more confused! When I moved my hand around over the steering column, it just added a reflection of my hand! It isn't the chrome, either, because I can also see it in the reflection, and when I tried to cover it nothing happened. I tried closing the cup holders, turning off the navigation screen, opening and closing the glass roof, rolling down the driver and passenger windows... the only thing that helps is turning off the halo lights... but that's what I'm trying to avoid. Anyway, thanks for the helpful comments. I hope someone figures this out...
I have the same thing as my halos are also blue. The reflection is caused by the chrome rings around the guages. I'm so used to it now, I don't even notice anymore.
