Notices
Sponsored By:
Sponsored By:
Getting ready to pull the trigger for a supercharger install
Old 8/15/15, 07:37 AM
  #81
STUKUP2112's Avatar
It's never gonna end!!!
Originally Posted by STUKUP2112
Base tune is in and were on the Dyno for the custom tune !!!!! If all goes well we'll pick it up tomorrow afternoon. Let's keep our fingers crossed !!!
Well we got another problem !!! It just never ends. We got it on the dyno to custom tune and we finally got some numbers. The car made 722 RWHP which calculated to 850 HP at the engine at 15lb of boost !!! The problem is that after 5500 rpm , the car goes too lean and even raising the voltage to the max on the pump, it was not giving it enough fuel. Only to find out my fuel pump , can not support that much hoarse power. Apparently, The upgraded 10 rib pulley kit I got with supercharger is creating that extra HP. If I stayed with the 6 rib it came with, there would have been no problem. Now we have to change the pump !!! So were looking at the GT500 double pump that will support more HP and a booster pump, so I can give it the enough fuel it needs to make the HP the supercharger wants to make. Meanwhile, I can take the car home and wait for the pump to come into the installer, but I have to baby it until we get the correct pumps installed !!!! But when it's finally done , it's gonna be more than what I expected it to be !!!! Tune in next week as the saga continues !!!
Old 8/15/15, 09:04 AM
  #82
SpectreH's Avatar
Received 1,155 Likes on 843 Posts
That thing will be a rocket when you get the pumps installed.
Old 8/15/15, 10:46 AM
  #83
Received 1,737 Likes on 1,234 Posts
Yeah,...after a certain size pulley, (79mm or smaller pulley, you need/should use new injectors and for 75mm or smaller pulley, you need/should use a BAP.) I may have missed it, but what are your supporting engine modifications? What did you do to the bottom end and your internals?
15lbs. of boost is awesome. Good luck! Keep us posted.
Old 8/15/15, 02:45 PM
  #84
STUKUP2112's Avatar
As far as I know, I cant find anyone who
makes a return-less style pump for my car to support that kind of power , it looks like I am going to go to a return style pump. Then there plenty in that style to support the kind of power I am making.
Old 8/17/15, 02:47 PM
  #85
STUKUP2112's Avatar
Since they don't make a return-less style pump for my car to support that kind of power , it looks like I am going to go to a return style pump. Then there plenty in that style to support the kind of power I am making.
Unless anyone can direct me to a aftermarket website that makes a returnless style pump for a 2012 Mustang GT
Old 8/17/15, 05:51 PM
  #86
Hope this helps Rick!
Good luck.
http://www.jpcracing.com/2011-14-gt-...el-components/
Old 8/18/15, 02:48 PM
  #87
STUKUP2112's Avatar
Thanks but none of them are return less. I am gonna have to spend buck on a return line fuel system. But first I gonna try to change the injectors to 75lb/hr and see if that fixes my car from running too lean. It might be a cheaper route/fix. We will see !!!
Old 8/18/15, 04:39 PM
  #88
STUKUP2112's Avatar
Whipple W175FF (2.9L) Stage 3 SC Kit Intercooled-10rib pulley kit w/ methanol injecti
Whipple W175FF (2.9L) Stage 3 SC Kit Intercooled-10rib pulley kit w/ methanol injection
850hp-722rwhp 15lb boost
Attached Thumbnails Getting ready to pull the trigger for a supercharger install-0814151103.jpg   Getting ready to pull the trigger for a supercharger install-0814151106.jpg   Getting ready to pull the trigger for a supercharger install-0814151109.jpg
Old 8/18/15, 04:44 PM
  #89
STUKUP2112's Avatar
Video of dyno pull
http://s1133.photobucket.com/user/st...tml?sort=3&o=0
Old 8/19/15, 12:14 AM
  #90
Cdvision's Avatar
You're a brave man. I don't mean to be a downer but I'd be nervous with a 5.0 with a stock bottom end grenading with anything over 625 rwhp. A guy out this way had his 5.0 fly apart with 680 rwhp and a "safe" tune. Meth injection isn't going to stop a rod from letting go. Good luck and start saving for a built shortblock if you plan on hammering on it often.
Old 8/19/15, 03:14 PM
  #91
That is definitely beastly!! SO nice!
^^What this guy said.
It's a beast. Good luck!
Old 8/25/15, 09:06 PM
  #92
STUKUP2112's Avatar
Listen, I know it's way over for that motor !!! Hammering it is not why I built it. I do see myself taking it too the track once or twice a year, spring/fall, a couple of passes each visit to get some times that it !!! I think it can handle that much !!! Otherwise, a few shows is where I will take it most. But thank for the advise anyway.
Old 8/26/15, 09:00 AM
  #93
DarrenGT's Avatar
WOW!! that's INSANE I SAY!! INSAAAAAYYYNNNNNE!
If it were me i'd be so scared jumping on it for any length of time, but at least you've got some cool numbers and ALOT to talk about at the shows
I hope it lasts a long time for you and you don't end up blowing a rod or ending up in the ditch. Hope you can handle that power from behind the wheel. Take some sport driver training
Also, what brakes are you running? Make sure you can stop that beast!
CONGRATS!
Old 8/26/15, 09:11 AM
  #94
JoeMidnight's Avatar
Congrats for sure! Here I am, a happy camper with my V6 stock motor pumping out 305HP running 87octane fuel. can't imagine what it'd be like to push 3,700lbs of metal down the road with 750+ HP to push it.
Old 8/26/15, 11:33 AM
  #95
5.M0NSTER's Avatar
Yeah, sweet build! Looks really sharp and great numbers!
Congrats and be careful, I'd also worry about something letting go with that much power.
How high are you running your motor RPM?
Old 8/26/15, 04:20 PM
  #96
STUKUP2112's Avatar
I have done up to 6000-6200rpm. I think it would be foolish to redline it !!! And the rpm I mentioned, so far were only on the dyno. I expect to take it to the track and get some times and again bring it only to 6200 rpm there.
Old 8/26/15, 04:57 PM
  #97
5.M0NSTER's Avatar
Smart. I'm excited to see your quarter mile time slip! Car will be a rocket!
Old 8/31/15, 09:02 AM
  #98
rmurer's Avatar
Man lay off the (!!!!!!!!!!!!!)
Also all it takes is once pass, to bend a rod, you are flirting with disaster. The power is addicting, but gotta learn the limits of the motor before its too late.
I didn't catch it did you get the oil pump gears replaced with billet ones. If not I don't give your motor a year. But hey welcome to the dark side.
Old 2/17/16, 03:40 PM
  #99
STUKUP2112's Avatar
Decided to change the engine
Haven't been on here for a while, but I have decided and bought a new engine more meant for my supercharger. I went with DSSracing to build it. Here's my engine summary:
DSS engine build summary
9.5:1 compression
Brand new Ford Racing aluminum block
Brand new 2012 Ford Racing coyote cylinder heads
Stage 1 comp blower cams
H-beam rods
Total seal style rings
Forged pistons
Complete ARP hardware and studs
Canton oil pan
New timing chains/guides/tensioners and gears
billet oil pump gears
Engine on it's way !!!
I will post status
Old 2/17/16, 05:54 PM
  #100
^^NICE!!!
There ya go Rick! Should be beastly. I assume you're keeping the Whipple and slapping it on there because of the blower cams? Going to up the boost a little?
Quick Reply: Getting ready to pull the trigger for a supercharger install
