Gas pedal temporarily inop
Old Mar 31, 2015 | 03:04 PM
Earlsays's Avatar
OK, OK, I know the real answer here is "don't be an immature moron" but humor me...For the record, my coyote powered 2013 F150 did this as well....My 14 GT behaves the same. Traction and stability control is active when this occurs. Situation is this, see a cool car drive by, throw it in Neutral, throw them a rev, back in drive, throttle is completely unresponsive causing a situation where it is almost necessary to pull over before the pedal will do anything....outside of the obvious "stop acting like a teenager" is there a fix for this?
Old Mar 31, 2015 | 06:44 PM
rmurer's Avatar
there are two types of people.
people who rev their engines at others.
and people who lie about doing it.
Anyway i don't have a solution for you but this has happened to me as well.
I usually throw into N, rev, let the rpms come down then put it back in drive.
Old Mar 31, 2015 | 06:46 PM
Press the clutch pedal in instead... jk haha!
Old Apr 1, 2015 | 05:41 AM
Just downshift and rev that way
Old Apr 1, 2015 | 06:23 AM
Earlsays's Avatar
Last night I tried it, going 50, neutral, high rpm rev, back to drive, pedal to the floor and stayed there, car did nothing - rpm fell to about 2 grand, with pedal pushed to the floor, when everything kicked back in, car decelerated as if downshifting from 4 to 2, and finally throttle went wide open-drive by wire is strange....
Old Apr 1, 2015 | 06:33 AM
CCTking's Avatar
I believe its a failsafe programmed into the computer to help prevent damage to the transmission (for autos at least) because my 02 would snap right back into gear from neutral but the dead zone happens to me as well. Once the rpms slow roll down to a safe point the tranny clicks into gear and goes
Old Apr 1, 2015 | 06:46 AM
dmhines's Avatar
It's traction control kicking in. It's hsppened to me also. The computer is sensing that what is about to happen will cause loss of traction so it stops it.
Old Apr 1, 2015 | 06:51 AM
CCTking's Avatar
I dont think its necessarily that because even when i have everything full off it still happens
Old Apr 1, 2015 | 06:55 AM
dmhines's Avatar
To fully turn off traction control completely you need to be stopped with brake pressed and hold button for 7 seconds. A message will pop up saying everything is off. ABS cannot be turned off.
Old Apr 1, 2015 | 08:32 AM
Automatic 5.0's Avatar
I have performed the "hello" rev and did not experience the dead pedal when going back to drive. However, yesterday, I revved while sitting still in neutral, then tried to put the car in gear before it had completely returned to idle and it would not go into gear until the idle was normal.
Old Apr 1, 2015 | 09:25 AM
CCTking's Avatar
I know all that
Old Apr 1, 2015 | 10:48 AM
FordService's Avatar
Hi guys,
As per my technical expert, this is a normal operating characteristic of the integrated powertrain software. The vehicle “sees” a neutral flare-up in conjunction with an RPM increase and vehicle speed decrease, the Powertrain does not know if the action was intentional (as described) or accidental (shifter was knocked out of position), so a power de-rate will occur for safety reasons.
Deysha
Old Apr 1, 2015 | 10:53 AM
Earlsays's Avatar
Originally Posted by FordService
Hi guys,
Deysha
Fantastic! Potentially, later on down the line, when the warranty is gone....I wonder if a tune could fix this?
Old Apr 1, 2015 | 02:06 PM
I won't comment on that, Earlsays. Lol! But, you're very welcome!
Deysha
Gill5oh
Oct 6, 2017 10:50 PM
NC14GT
Sep 10, 2017 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
Sep 8, 2015 10:45 AM
