Final track pack thread
Old 10/24/13, 10:23 AM
  #41
Azure's Avatar
Originally Posted by Brandon302
What people are arguing seems to be, unless the rods are completely the same on every 5.0 mustang, why would Ford add forged rods to the rotating assembly but then slap the stock pistons on. The rods and piston probably come as a single piece before bolted onto the crank, so there would really only be two configurations, Boss and GT. All of the other mods seem logical that they would slap the pan, cooler, rad and what not on after the fact.
^Yup, and if the Boss mani and factory tune are not used, what would be gained? Seems like that would be the only way you would get the higher RPM gains with said Boss'ified track pack.
Old 10/24/13, 10:31 AM
  #42
TheReaper's Avatar
Originally Posted by Gogoggansgo
Good point but my source at plant told me that they are using up all the extra parts before the turn over at flat rock for the 15s
The engines are not built at the Flat Rock plant.
Old 10/24/13, 10:53 AM
  #43
ThrustangFiveO's Avatar
Here it is...
Gave the last 8 digits of my VIN to the parts dude and this is what i found:
My 13 TP GT:
Connecting Rods P/N: BR-3Z-6200A
Crankshaft P/N: BR-3Z-6303C
A 13 Boss 302:
Connecting Rods P/N: CR-3Z-6200A
Crankshaft P/N: CR-3Z-6303A
Myth busted. Sorry fellow Track Pack brethren's, it is what it is.
Old 10/24/13, 10:54 AM
  #44
Gogoggansgo's Avatar
Lol they are made at the Essex engine plant
  #45
**** o well ill edit the original post at least we have the part number for everything else
Old 10/24/13, 10:57 AM
  #46
Done edited original post
Old 10/24/13, 11:47 AM
  #47
5.M0NSTER's Avatar
Thanks OP, and Thurstang. I was wondering about this topic. Now we know. Well done.
Old 10/24/13, 11:48 AM
  #48
JScottGT's Avatar
Originally Posted by ThrustangFiveO
Here it is...
My 13 TP GT:
A 13 Boss 302:
To further throw a wrench into things here... here is some better clarification of the part numbers you have listed, along with actual Ford P/N spacing
Con Rods : BR3Z-6200-A vs. CR3Z-6200-A
The only difference between these part numbers is the prefix, which just identifies the model year they were released for.
B = 2011
C = 2012
The rest of the part numbers being identical, leads me to believe they are actually the same part, even the same "A" suffix. Although this may not necessarily be the case. A regular 5.0 engine assembly could call for the BR3Z part, while the Boss engine assembly could call for the CR3Z part.
Crankshafts: BR3Z-6303-C vs. CR3Z-6303-A
These part numbers have both different model year and suffix differences. This lends me to believe they are in fact different parts completely. The difference in suffix is really where the difference comes in. In this case, the A suffix looks like it's the forged, and the C suffix looks to be the cast version.
Old 10/24/13, 12:55 PM
  #49
Black Fire's Avatar
Nice to see that the truth comes out after someone puts forth a little time and effort.
Good Job ThrustangFiveO.
Don't fret it TP owners you still have one bad *** factory Mustang.
Old 10/24/13, 02:44 PM
  #50
5.M0NSTER's Avatar
+1
Old 10/24/13, 03:51 PM
  #51
texasgtguy's Avatar
Are you on pot?
Old 10/24/13, 04:23 PM
  #52
steven46746's Avatar
I think my track pack may be a NA 5.8
Old 10/24/13, 04:45 PM
  #53
Lol maybe the next mach 1
Old 10/24/13, 04:58 PM
  #54
Ltngdrvr's Avatar
For clarification, the GT crank is not a casting, it is forged, as is the Boss.
The difference is the balance, the GT is balanced for the powdered metal rods and cast pistons, the Boss for the forged rods and pistons.
Old 10/24/13, 06:22 PM
  #55
miner999r's Avatar
My verdict is the track pack is still a nice package for the price. upgraded components done factory correct with full warranty. A nice package to build on when the warranty honeymoon is over, so I feel good about my machine. it still has enough power to get me jail time if I abuse the privilege. Alas no race tracks for me to run on where I am. Drag strip but I just can't bring myself to thrash the car.
Old 10/24/13, 07:11 PM
  #56
JScottGT's Avatar
Good to know. Thanks
Old 10/24/13, 10:59 PM
  #57
Ltngdrvr's Avatar
There's no doubt at all that the Track Pack is an outstanding value for the components it adds over the basic Brembo package.
Of course if you're not road racing the car, all those extras are just good for bragging rights.
Old 10/26/13, 02:27 PM
  #58
kaineoutlaw1213's Avatar
The 2013 gt has the same aluminum block as a boss. They do have forged cranks, some kind of coated pistons and rods the reason you get diff part numbers for the boss vs gt is that they are diff. The gt has forged crank and hyp pistons and looks like standard rod. The boss has a BALANCED forged crank, matched by the BALANCED piston and rod set. So they are deff diff but the gt did get upgraded in 2013. They also def have no oil squirter at all for the piston. Im a tech at ford and we just took a 2013 apart trying to identify this tick issue. We ordered all new parts and I have a 2011 I blew up on boost that I had the parts laying around still. They are def diff pistons crank and block w no oil squirter. i still dont get why it matters. W out the rods and pistons to match a forged crank it doesnt matter a bit. The crank has never been the weakest link lol! And you cant just throw boss rods and pistons on a gt crank due to the balance. But you can throw mmr rod and piston set on the gt crank and be stronger than the boss and the boss would have to rebalance for the manley rods n pistons. But yea thats whats up w the numbers. This applies to all 2013 gts not just the track pack.
Old 10/26/13, 03:54 PM
  #59
14Glassback's Avatar
When I had my Track Pack in for the Timing Cover oil leak, I also asked the Master Tech who worked on my vehicle to listen to the clutch. I had a noticeable noise from the clutch (Not the Pedal) when letting the clutch out. He thought the noise was not an issue and mentioned he thought the Track Pack cars had a different clutch than a standard GT. Anyone else heard of this?
Old 10/26/13, 04:24 PM
  #60
Oh lord! Lol
Quick Reply: Final track pack thread
