don't laugh
Old Mar 23, 2015 | 07:50 PM
dohc97's Avatar
don't laugh
How do I remove the two plastic wing fasteners in the trunk? It just keep on turning. These are the fasteners holding the plastic panel right behind the tail lights. I am trying to install the Raxiom tail light sequencer.
Old Mar 23, 2015 | 08:21 PM
Jazzman442's Avatar
On my 2006 I have to pull on them and turn at the same time... not sure why but I have the same problem as you and that they just spin.
Old Mar 23, 2015 | 08:31 PM
Getportfolio's Avatar
They are snapped in with little teeth even though they spin. Good luck getting them off without breaking them.
Old Mar 23, 2015 | 08:33 PM
HizliBullet's Avatar
be patient and keep turning it like a can opener
Old Mar 23, 2015 | 08:48 PM
Wish I had a pic. Trust me. They snap and lock. I would get two new ones from ford..cost like 2 bucks and pry the others off carefully.
They break easily...,hence the extras.
Old Mar 23, 2015 | 09:05 PM
mustangfan410's Avatar
I'm trying to remember how I got the pins out, cause one of mine spun too. If you pull on them gently as you turn they might come out.
Old Mar 23, 2015 | 09:28 PM
Azrael's Avatar
I had the same problem and ended up breaking both doing the GT500 valance install. I just ordered 6 from Tousley/Autonation parts for extras.
Old Mar 24, 2015 | 05:01 AM
tbone004's Avatar
The upper 2 behind the tail lights will unscrew, but you may have to pull them off when they are loose enough.
The bottom 2 will need to be pulled out, they are push in type connector. I used my side cutters before purchasing a tool to remove these types of connectors. Put your cutter blades under them and pry up, being careful not to squeeze and cut them.
Old Mar 24, 2015 | 06:22 AM
dohc97's Avatar
Do you happen to have the part number?
Old Mar 24, 2015 | 05:13 PM
Azrael's Avatar
Sorry, I missed the notification on this reply!
The part I ordered -W714997-S300 REAR TRIM PANEL UPPER RETAINER
Old Mar 24, 2015 | 05:36 PM
dohc97's Avatar
I just got it done. I just used a regular plier to take it off.
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
CoyotePremium13
Oct 7, 2015 07:17 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
