Changing oil question
Old Aug 19, 2010 | 11:42 AM
Huskernation's Avatar
I will be changing my oil soon and remember reading something about a cover by the oil drain. Is this correct? Do I need to remove this before draining or is there an easy way around it? What about resetting the computer ofter the change?
Old Aug 19, 2010 | 11:47 AM
Ltngdrvr's Avatar
The cover is over the filter and there is a removable panel.
Still will probably get oil on it but just keep a rag handy.
Old Aug 19, 2010 | 11:56 AM
ahh ok thanks. I have not been under the car yet other than a quick peak. Any idea if a gt will roll up on a regular set of ramps without scraping?
Old Aug 19, 2010 | 12:04 PM
RedWings's Avatar
I use a set of rhino ramps I got from Advance Auto without any problems w/scraping.
Before doing the oil change, pick up a box of store brand freezer bags (1 gallon size). Loosen the oil filter to where you can turn it by hand w/o much force and before any oil leaks out. Then place the bag around the filter/housing so it catches any oil that leaks out when you get the filter off. This will keep from any oil getting on that cover.
The first time you do this it will seem kind of tricky. But it is not tough to turn that oil filter while the bag is over it.
(Thanks to the member who brought this to our attention. Works like a charm.)
Old Aug 19, 2010 | 12:19 PM
Thanks for the information.
Old Aug 19, 2010 | 02:52 PM
Bert's Avatar
Originally Posted by RedWings
. . . . Then place the bag around the filter/housing so it catches any oil that leaks out when you get the filter off. . . .
great tip on the bag, that would have kept the mess off my driveway too
(it's been a while since I've done my own oil changes, forgot how much oil comes out of the filter)
You'll need a set of real low profile ramps -- the ones at my local Advance weren't low enough for my 2010 . . . but I do mine in the driveway sloped down, so that when the car is up on the ramps it is pretty level, which makes the ramp clearance problem worse.
Mpaps
Oct 11, 2017 08:06 PM
dblhelx
Oct 6, 2015 08:08 PM
Fernando.4ohh
Sep 10, 2015 03:35 PM
Sep 10, 2015 12:44 PM
