Brembo brake pad & rotor replacement / life?
Old Sep 28, 2012 | 05:51 AM
Overboost's Avatar
Originally Posted by SpiderX1016
I see. I wouldn't be too happy if I had to replace the rotors every brake job.
Typically you don't, but like I said, I have a full set of rotors for track use as well now.
Old Sep 28, 2012 | 01:12 PM
Musker's Avatar
Don't you have to use the same pads + rotors combination each time to avoid warping the rotors or something?
Old Sep 28, 2012 | 01:29 PM
Overboost's Avatar
I'm going to have them resurfaced, so this won't matter. I know you need to remove any gouges in the rotors prior to new pad installation, but I don't believe this will affect them for occasional track use.
Old Sep 30, 2012 | 03:08 PM
Overboost's Avatar
Finished the rears today. Much easier than I anticipated. I did need the tool to run the piston back in, but that was the only hurdle I ran into. The outer pad on the drivers side was worn worse than any of the others, down to bare metal. The passenger side still had a bit of pad left on both. Big thanks to JScottGT for the tips on the install.
Old Sep 30, 2012 | 03:10 PM
11SHELBYGT500's Avatar
Whoa too far
Old Sep 30, 2012 | 03:45 PM
Overboost's Avatar
Whoa too far
Yeah, tell me about it. I'm still curious about the abnormal wear on that outer pad. Like I said, the pass. side was normal and uniform on both sides.
Old Sep 30, 2012 | 06:52 PM
steveespo's Avatar
Left rear seems to be the wheel that stability control uses the brake on most to control wheel spin and yaw. If you drive the car hard with TC on you will use up that brake. Discovered this when I was road racing and keeping Advance Track on as a safety net. Left rear would always be red hot.
Steve
Old Sep 30, 2012 | 07:21 PM
Overboost's Avatar
Steve
Good to know, thanks.
SVS
Oct 13, 2015 08:57 AM
lowblustang00
Sep 5, 2015 12:18 PM
spqr
Aug 10, 2015 01:37 PM
Jul 30, 2015 06:47 AM
