Boss intake where your limiter?
Old 11/17/13 | 02:47 PM
Originally Posted by Gogoggansgo
I see good point I only want to go to 7200
Makes sense to me. And keep in mind - though many want to eek out every little horsepower at the top end on a graph - the real question for real world driving is "where will I be in the power band when I upshift to the next gear?". If you are at the point that the next upshift puts you at or near peak torque, no need to stay in the lower gear for every little bit of rpm to redline... shift and ride the power band to the top again.
Old 11/17/13 | 08:14 PM
steveespo's Avatar
I spin my Boss/Steeda/85mmBBK/ARH combo to 7400. Make 432 @6950 rpm, about 410 at 7400, on track I shift 3-4 at 7400, 4-5 at 7200. Have run like this fo almost 6000 track miles and 23000 overall.
Steve
Old 11/17/13 | 08:41 PM
5.M0NSTER's Avatar
Originally Posted by cdynaco
Let me state that differently - looking at the improved readings with the tune, the tune flatlines about 7k. So why worry about spinning higher than 7k? Why worry about 7.6 - 7.8?? I don't see any hp gain past 7k....
Ditto. Based on that I'd set the rev limit at 7100. Pick up a few MPH in each gear. Why spin higher for virtually no gains?
Higher RPM makes sense for Boss guys as that engine is made to rev higher. But for a GT engine playing it "safe" would be 7000-7100 RPM in my opinion.
Old 11/17/13 | 09:36 PM
Ltngdrvr's Avatar
You never shift at the power peak, always shift past the peak so that when the revs fall back in the next gear the engine doesn't fall completely out of the best power range. This is the reason to rev beyond 7K.
When my car gets to the rev limiter it is still pulling like a freight train, wants more rpm, and this on a stock tune.
Old 11/17/13 | 09:42 PM
That surprises me you would say that with a 6spd.
Using the graphs as my guide (with the tune) are you saying if you upshift at or just below redline that you are lower than 4k (peak torque) on the 5.0 w/6spd?
Old 11/17/13 | 10:22 PM
Ltngdrvr's Avatar
Don't know what graphs you are looking at, not that it matters. You go to the track with a Mustang GT with the rev limiter set high enough and truly try both ways of shifting and the one shifting above peak power 300-400 revs will be faster.
Old 11/17/13 | 11:31 PM
bob's Avatar
bob
I know nobody has the answer I want mine in the safe zone
factory rev limit + 400 rpm
Ford sets the valvetrain up so that its stable for an additional 400 rpm over the factory rev limit. After that its hit or miss.
Old 11/18/13 | 02:10 AM
Gogoggansgo's Avatar
Agreed but what would that be at the general idea is that our limiters are at 7000 but this is another hit or miss subject
Old 11/18/13 | 02:13 AM
Thanks for the info cause at auto cross and even the track it's hard sometimes not to hit the limiter I done a few times myself it doesn't nothing unless unless u hit the limiter every chance and I have a brother who has a 2.3 ranger he beats the **** out of it to point of like calm down dude lol and he bounces it for seconds at a time lol
Old 11/18/13 | 08:18 AM
Ltngdrvr's Avatar
6800 factory rev limit on the GT.
Old 11/18/13 | 10:46 AM
7150 is where I going to put mine then thanks
Old 11/18/13 | 11:00 AM
TheDivaDanielle's Avatar
So then just raise the rev limiter to like 7200 on a stock intake GT and call it a day. don't even bother with the boss intake at that point, you won't be any faster.
Old 11/18/13 | 07:06 PM
Ibnzmonkey's Avatar
Replace valve springs for added cushion.
Old 11/19/13 | 03:58 AM
i honestly disagree thanks for the advise but the dyno chart dont lie its not like it the boss intake starts making power at 6000 rpm 5500 and it takes of im going for look alone is worth it
http://www.musclemustangfastfords.co...stant_manager/
Old 11/19/13 | 09:01 AM
AMDanBailer's Avatar
Former Vendor
Steve
^ This is what I run also! My car continued to make power up to about 7,500 so I start getting ready to shift around 7,200 so the shift is right around 7,400 RPM.
Anywhere from 7,100-7,500 is good to go. These cars love to revved out!
Hope this helps.
-Dan
Old 11/20/13 | 07:28 AM
bob's Avatar
bob
I'm waiting to see if Comp Cams introduces a set of conical valve springs for the coyote. They are focusing on the LS engine but it looks like a really promising technology.
Cobiecane
10/23/15 09:44 AM
exgto
2012-2013 BOSS 302
10/7/15 02:47 PM
10/2/15 02:00 PM
RoushRS3
9/29/15 09:03 PM
