Battery Question...
Old Mar 16, 2014 | 06:26 PM
14Glassback's Avatar
Had a relatively nice day today... And I wasn't crazy busy doing something else. So I uncovered the Mustang. I installed the battery again which I removed in November. My question is does everyones battery move left to right approximately 1/4 to 1/2 inch? My battery is flat in the tray. The hold down strap and bolt are in place and the bolt is tight. I double checked everything. Just do not remember it moving before. It is the original battery. Thanks!
Old Mar 16, 2014 | 06:37 PM
dmichaels's Avatar
Should be zero movement of a battery
Old Mar 17, 2014 | 10:57 AM
Figured out my issue. Was a simple mistake really. The battery heat shield cannot be installed under the hold down strap. It allows the battery to move. You have to bolt battery down, then put on heat shield. Then install battery cables. Nice and tight now!
Old Mar 17, 2014 | 04:32 PM
dmichaels's Avatar
Good you got it resolved!
Old Mar 17, 2014 | 04:59 PM
Tron84's Avatar
?? My hold down strap is on the outside of the heat shield and I don't have any side to side movement. I've had my battery out a few times and I've always left the "foam" on the battery when going in and out.
Pic for reference, is this the same as yours?
Old Mar 17, 2014 | 06:29 PM
I had to have mine the other way or I could not get the battery to stop moving. It was not much... 1/4 to 1/2 in left and right. I took lots of under hood pictures when I got my car... But none directly of the battery. I could see it in the corner of one picture and it appeared as though the foam was over the strap. That is what gave me the idea to try the other way. If the battery is tight I am sure it does not matter. But I think the way I have it now is factory?...
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
PonyMuscletang13
Sep 24, 2015 01:40 PM
