Base Radio Swap for Navigation
I have a base model 2010 GT without Sync and was wondering if anyone knew what it would take to get the factory style navigation setup. If anyone knows the part numbers from Ford that would be great and also if I would need the sync setup to make it work. (If I would also need the sync, what part numbers would correspond to that). My goal is to have an in dash navigation system, but Im not a fan of the kits that put the unit down towards the shifter, it seems like an odd place to look for the directions.
Thanks for the tip, is there any problem with actually using the system since its so close to the shifter? With that kit, it seems that it would be really low and in front of your knuckles when shifting.
I don't think it's a huge problem. Definitely not concerned during regular shifting.
It's very rare that I change the radio station by mistake but it does happen, it being a touch screen and all. I have found that in my laziness, leaving the charge cord for my phone dangling near the radio also changes the station. I either remove it or plug my phone in - like I am suppose to do...lol.
Head unit also plays DVDs, is an SD card reader, and has a jack for your IPhone/IPod. The price on that link is Pioneer's FULL retail price. I've seen it for much less.
Last edited by a50cobra; 2/2/12 at 01:36 PM. Reason: Oh yeah, and the Bluetooth allows for handsfree phone calls.
These were taken with my phone, so they are not the best. The second one is to illustrate how you don't have to worry about reaching the screen while shifting. I was in 1st gear there. Of course YMMV if you shift with your fingers extended for some reason .
Maybe I'm a little late to the party and this is a bad picture. Here is a shot of my Kenwood DNX9980HD. By far my favorite stereo I've ever owned and wouldn't go oem for the navigation. This thing could run OBDII diagnostics in real time if I wanted it to..
Install an aftermarket, non-factory, radio raises the risk of break-in to your car, and will cost about $500+ depending on what you choose.
If you simply install a bracket for a smart phone that has better navigation than any radio will offer, $50.
Or is you don't like your phone, get a GPS unit that mounts to a suction cup mount on the windshield that can be quickly plugged in to become functional.
If I were looking to add navigation to any car, the last thing I would choose is to install a Navaigation radio. My choice would be navigation via smart phone.
There have been a few that are not happy with the factory maps that come with the factory Nav system. There was an update released not too long ago; perhaps this addressed the issue of the maps being out of date.
As it has been discussed before, buying an aftermarket GPS for hundreds less a better solution, unless you just gotta have the factory setup. I like the sync option on my non nav setup, so spending the bucks to make it a factory nav with sync is not worth it to me, as my hundred buck tom tom works great, and downloading the latest maps is easy as well.
Unfortunately, no the steering wheel will not function the head unit. There may be some additional wiring and hardware that can accomplish this, but I don't think it was worth the additional effort and money. Just my $0.02
Here is the link to the thread for my install: https://themustangsource.com/f803/pi...nstall-503772/
And here is a little better picture.
Since you can do a plug and play swap with a premium steering wheel and the shaker500 and the buttons work, I would assume the wiring harness is there and you could do the same with an aftermarket stereo and a PAC adapter.
