Is anyone changing their auto tranny fluid early?
Old Nov 3, 2014 | 01:46 PM
70monte's Avatar
I know their are some differing opinions of tranny fluid changes on the Automatic transmissions in these new Mustangs. I'm not very familiar with these transmissions other than I've heard they are pretty durable.
Should I think about changing the fluid earlier than what the manual says or stay with the manufacturer's recommendation? Thanks.
Wayne
Old Nov 3, 2014 | 03:36 PM
GrabberBlue5.0's Avatar
I changed mine with less than 5000 miles with Amsoil but only because I was installing a converter.
Old Nov 4, 2014 | 04:16 AM
David Young's Avatar
I'm having my dealer 'flush' mine on my 2011 v6 next month. It will have less than 22,000 miles but will be 4 years and 7 months old. I don't like having old fluids in my Mustang
Old Nov 4, 2014 | 07:03 AM
silverstate777's Avatar
I was wondering about that too, as the owners manual states a 150,000 mile service interval. Since I’m running mild forced induction with a stock transmission, the current plan is sending a sample on my ‘14 GT to Blackstone for a UOA analysis at the 30,000 mile mark and see how it goes.
Old Nov 4, 2014 | 07:42 AM
70monte's Avatar
I was reading on one of the F150 forums and watching a youtube video that this one Tech put out about changing the fluid in one of these transmissions. He recommends changing the fluid and filter every 60,000 miles because he says the solenoids inside the tranny are sensitive to dirt and debris. I've read other things that recommend changing the fluid and filter out early to get all of the break-in material out.
They make changing the fluid on this transmission so difficult that it's hard for the DIY'er to do it. You almost have to take it to the dealer to get it done and they just want to flush it and not change the filter. Thanks for all of the replies so far.
Wayne
Old Nov 4, 2014 | 03:21 PM
Wayne
I found it very easy to change. Just drop the pan and refill using the dipstick. This included pulling the transmission to do a converter.
Old Nov 4, 2014 | 04:36 PM
70monte's Avatar
How did you get the fluid level correct since supposedly the fluid has to be at a certain temp to get an accurate reading? How did you get the car up high enough so it would be level so you could check the fluid level with the little dipstick that is on the transmission?
Wayne
Old Nov 4, 2014 | 04:47 PM
dave07's Avatar
I just changed the transmission fluid and filter on my 2004 ford ranger with 127,000 miles on it. The fluid was still bright red and I noticed no difference with shifts or anything with the new fluid. Hindsight, it was probably a waste of money to change.
I would say if you are racing and running over stock horsepower than it might be a good idea to change the fluid at a sooner interval than what the manual says.
Old Nov 5, 2014 | 08:15 AM
Wayne
I did mine on a lift but if it was being done on the ground it certainly wouldn't have been as easy.
Old Nov 5, 2014 | 09:10 AM
Dubya's Avatar
Depends on your driving....changed mine at 22,000 miles to Mobil 1 to try and improve shifting performance...seems to have helped...will probably change every 5-8K miles as car get to the track 8-10 days a year
Attached Thumbnails Is anyone changing their auto tranny fluid early?-snowsnake.jpg
Old Nov 5, 2014 | 09:12 AM
Critical Mass's Avatar
I've seen Transmission Fluid last 10+ years without being changed, but I'll just follow the recommended time/mileage, whichever comes first.
Old Nov 5, 2014 | 06:25 PM
70monte's Avatar
I had the front of mine up on ramps today fixing a little boo boo I did to the front bumper lip and looked at where the fill plug was for the tranny. It is very close to the cat and doesn't look like it would be much fun to take out with the car hot.
I have an aftermarket dipstick that goes up into the engine compartment that I was going to install but it looked like it was going to be a big pain trying to get it past some wires and exhaust that was in the way so I decided to leave it for a day when I had more time to mess with it.
Wayne
Old Nov 5, 2014 | 07:38 PM
TheReaper's Avatar
I will never change the fluid.
Fastnloud
Feb 15, 2016 05:21 PM
Evil_Capri
Oct 14, 2015 12:18 PM
GTPETE
Oct 12, 2015 02:20 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
sum1
GT350
Sep 13, 2015 04:41 PM
