3m Carbon fiber wrap
Does anyone know if I will need adhesion promotor for 3m wrap. I will be using it on the interior and exterior.
Unless I'm mistaken, Adhesion promoter is usually only needed to strengthen adherence to plastic and you never want to get it on paint as it will destroy clear coat. That's why you always put it on the plastic piece (scoop, louver), then apply the 3m adhesive. You only use alcohol on the metal painted surface.
Definitely use the promoter on interior pieces because I had issues with the wrap staying adhered during the summer months. I re-did my 2 areas with promoter and then I had no more issues.
