2013 LCD display
Old Feb 14, 2015 | 12:18 PM
backin15's Avatar
2013 LCD display
The bottom of my LCD display seems to be too low and cut off. It is noticeable if manually shifting and in 2nd gear and the 2 looks more like a question mark. If I sit very upright the bottom of the 2 appears. Is this normal?
Old Feb 14, 2015 | 12:38 PM
SpectreH's Avatar
My '13 GT does it a little, but not as pronounced as yours.
Old Feb 14, 2015 | 01:00 PM
xtc.inc's Avatar
Fit and finish my friend. They did not center the screen properly at the factory when they assembled the gauges. Seen this before... couple threads on here. You can take it apart yourself and move it up slightly.
Old Feb 14, 2015 | 03:45 PM
backin15's Avatar
Thanks - if it is something I can fix myself I would rather take care of it than take it to the dealer.
Old Feb 14, 2015 | 03:57 PM
mustangfan410's Avatar
Mines low too but it's not as bad as yours. I can still see the bottom of the numbers.
Old Feb 14, 2015 | 03:59 PM
dmhines's Avatar
A dealer would not disassemble the cluster and adjust the overlay. They would probably insist a new cluster be ordered.
Old Feb 14, 2015 | 06:36 PM
Blown CS's Avatar
Mine is that way and I posted it up about a year ago asking the same thing.
Old Feb 14, 2015 | 11:40 PM
backin15's Avatar
Did you ever fix it and if so did you do it yourself?
Old Feb 15, 2015 | 07:42 AM
SpectreH's Avatar
Since mine is barely noticeable and can only be seen when in manual shift mode, I haven't bothered.
Old Feb 15, 2015 | 08:00 AM
Blown CS's Avatar
I pulled the front of the instrument panel off and it looked at it and decide too much needed to be removed to worry about. It's covered under warranty and I might have them look at it if I need to take it in for additional warranty work.
Old Feb 15, 2015 | 08:07 AM
Blown CS's Avatar
Here is a link to my thread and it had more info in it.
https://themustangsource.com/forums/f726/display-low-select-shift-531627/
Old Feb 15, 2015 | 09:05 AM
TheReaper's Avatar
Here's mine.
Old Feb 15, 2015 | 10:18 AM
backin15's Avatar
Thanks for the link, Blown. Mine looks quite similar to yours. I think I will have the dealer look at it, I expect them to say there is nothing wrong since it appears normal unless you are in a comfortable driving position. They will probably say I have my seat reclined too far.
Old Feb 16, 2015 | 08:00 AM
FordService's Avatar
I also agree with your bringing it in to your Ford Dealer and getting it checked out, backin15. Please let me know what they say.
Have you addressed this with your dealer, SpectreH?
Deysha
Old Feb 16, 2015 | 01:00 PM
SpectreH's Avatar
Deysha, I have not talked to the dealer. Mine is barely noticeable when in manual shift mode. You can't tell in auto shift mode.
Quick question: Would I need to return the car to stock (intake/tune) for warranty work?
Old Feb 16, 2015 | 06:47 PM
backin15's Avatar
[QUOTE=FordService;6899242]I also agree with your bringing it in to your Ford Dealer and getting it checked out, backin15. Please let me know what they say.
Thanks, Deysha - I'll bring it in when the snow melts.
Old Feb 17, 2015 | 09:31 AM
I don’t have say so on that, SpectreH. I recommend you speak to your service manager about this.
You’re welcome, backin15! Keep me posted.
Deysha
Old Oct 11, 2015 | 10:37 AM
backin15's Avatar
Update - since my warranty is about to expire I decided it was time to have them take a look at the LCD issue. They first tried to have me sign off on a diagnostic fee of up to $100, saying if it is normal Ford won't pay them for the labor to check it and it would be my responsibility. After 10 minutes of heated negotiation they reduced the fee to $50 then finally waived it.
Later that day I received a call that my car was done. When I asked what they found they said nothing, it is normal. I argued that it is not normal to have the lower part of the display cut off and they said it is "within tolerances".
I raised the white flag and went to pick my car up, only to find a big greasy hand print on my door.
Quite the opposite experience from when I took our Nissan in for service, our filthy car was returned washed and vacuumed.
Why am I feeling glad my warranty is up?
Rando
Aug 25, 2021 11:12 AM
trackpack13gt
Jul 25, 2017 05:29 PM
UOP Shadow
Sep 27, 2015 07:24 AM
DarrenGT
Sep 19, 2015 01:00 PM
