2011 Mustang Paint Blistering
Old Feb 20, 2015 | 07:00 PM
Rjager0216's Avatar
Paint is blistering on hood front edge of 2011 Mustang with 39k miles. Ford will not repair because it is not perforation. This is an obvious paint defect from manufacturer. Where's the quality in Ford products?
Old Feb 21, 2015 | 06:43 AM
Onelildude's Avatar
My 2010's hood did the same thing and my dealer would fix it either.
Old Feb 21, 2015 | 01:08 PM
tony2014mustang's Avatar
Do you have any pictures of this? I have heard people complain about this before. I have a 2014 and I am looking under the hood constantly. Thanks
Old Feb 21, 2015 | 01:42 PM
houtex's Avatar
There are at least four other threads this has been going on in, from all years, 2005-2014, and may be more than that:
https://themustangsource.com/forums/...nt-ugh-507379/
https://themustangsource.com/forums/...n-hood-491504/
https://themustangsource.com/forums/...rosion-532133/
https://themustangsource.com/forums/...p-hood-522361/
And since the paint and body is NOT under 5/50K warranty (as that's powertrain only), but the 3/36, any car which was not bought new in the years of...well, today's date in 2012 and on are out of luck on this. (as of this writing in Feb 2015.)
It will *never* perforate. Not in your lifetime anyway, not without a heck of a lot of help. One of the better aspects of Aluminum alloy... Once it oxidizes, it protects itself from further 'rusting'. Unless an agent is applied to cause it to corrode more. Sucks for paint though, it already doesn't want to hang on to the paint, and then it turns underneath... paint pops right off.
Only hope is to replace the hood with another and hope its ecoat is good, or get an aftermarket plastic/fiberglass one (or steel if you can find it, good luck), or strip it and prep it properly and repaint off the car and remount it.
It is the one thing they shouldn't have done on these cars, use Aluminum, unless you were going to do it *everywhere*.
Old Feb 21, 2015 | 02:23 PM
Rjager0216's Avatar
Car is garaged most of the time.
I will try to add pics. It is occurring on front edge.
Old Feb 21, 2015 | 02:26 PM
Rjager0216's Avatar
Can't wait to see how new aluminum trucks hold up.
The car is in garage most of the time in SC. Ford would not consider doing anything.
Old Feb 21, 2015 | 02:36 PM
Rjager0216's Avatar
See attached pics.
Old Feb 21, 2015 | 02:40 PM
Rjager0216's Avatar
Was told 3 yr bumper to bumper would cover issue, but not 5yr/ 50K paint warranty was only perforation.
Old Feb 21, 2015 | 02:41 PM
Rjager0216's Avatar
It will probably take a lot of complaints before Ford may consider doing something. I may try BBB but may not have a technical leg to stand on since it is not perforation.
Old Feb 22, 2015 | 12:21 PM
houtex's Avatar
At this rate, it will take no complaints, for Ford generally isn't budging on this. They've pretty much taken a 'did it last through the warranty? Then our job is done! Movin' on...' attitude about it.
Your best bet again is to get it repainted by a facility that knows how to paint it, or replace it with one that's more amenable to being painted in the first place.
Regarding the all aluminum F-150... the amount of steel vs aluminum might just abate some of the corrosion issues. The other part is that they aren't going to be dunking assembled steel and aluminum chassis and bodies into the same tanks, so any contamination from the steel won't be had, ostensibly.
I daresay that after thinking about it quite a bit, regardless of my previous posts about how the paint's going to fall off... they might actually have a chance at having sticking paint on the F-150, due to the fact that it is *all* aluminum, and not just the hoods.
Time will tell on that, of course.
Old Feb 25, 2015 | 09:12 AM
CriticalmassGT's Avatar
Don't forget to add that they are spending hundreds of millions of dollars to help update dealer body shops to prevent these issues from occurring when bodywork has to be done.
Old Feb 25, 2015 | 09:24 AM
SVS's Avatar
SVS
It happened to me twice..Both times the dealer fixed it under warranty. The second fix the Body Shop covered because their first one failed and the bubbling came back. I was shocked they got the paint matched and blended.
Also HB Ford uses a contract Body Shop in the area, it's not an in-house part of the service department.
Ideally the repair holds
Old Feb 25, 2015 | 10:47 AM
VidPro's Avatar
Legacy Tms Member
How long did it take to come back? I had my hood done late summer and its been parked in the driveway covered since late October early November.
Old Feb 25, 2015 | 11:35 AM
SVS's Avatar
SVS
The Vehicle is a 2011 I bought in October 2010. First repair was March '13 and second was May '14.
The second time it was on both sides of the hood.
Old Feb 25, 2015 | 12:40 PM
dave07's Avatar
Same situation as you. My hood is starting to bubble again. So about 6 months or so. Also, on the top of the hood I'm getting some sort of paint failure. I'll be asking for a new hood.
Old Feb 28, 2015 | 07:50 AM
VidPro's Avatar
Legacy Tms Member
Bummer. Right before I put her away I looked at it. It looked great but I have this bad feeling once the snow melts off the cover and I take my first look it'll be back. I really don't want to go through an endless dance with this issue. Every time the car goes in it has a chance of a ding or other disaster.
Old Feb 28, 2015 | 06:17 PM
JohnnyMustang2's Avatar
I come to accept that, There is none!!
Old Mar 11, 2015 | 11:38 AM
Folks, if you have been denied warranty coverage and Deysha was not able to successfully have this issue resolved for you (or it was repainted/replaced and the issue came back), there is another option now. The below attorney has filed a class action lawsuit against ford for this specific issue on behalf of two mustang owners. He is looking for more people who have gone through the ringer and haven't had a successful resolution.
I'm only posting this because I think Ford should permanently fix the issue. in the end it hurts their brand image to have cars running around with what looks like car-herpes on the aluminum.
http://www.sommerspc.com/en/people/l....aspx?ORID=192
Old Mar 11, 2015 | 12:41 PM
dave07's Avatar
That link does not work.
Old Mar 11, 2015 | 01:39 PM
sommerspc.com/en/people/lance-c-young.aspx?ORID=192
The Attorney's name is Lance C Young. He's the one handling the lawsuit.
Same site, just look up Lance C Young on their website. The auto-linking is cutting his name out of the link after a time.
