2011 Mustang Info.
Old Dec 28, 2009 | 11:12 AM
  #81
eci's Avatar
eci
Originally Posted by MARZ
You won't need to run much boost.
Is that why we have 24 PSI GT500's out there with 850RWHP?
Old Dec 28, 2009 | 12:32 PM
  #82
stangfoeva's Avatar
MOTM Committee Member
I'm not trying to attack you, but goodness man not eveything is about the GT500.
I'm sure MARZ wasn't even thinking about it in his post
Old Dec 28, 2009 | 12:42 PM
  #83
MARZ's Avatar
Swamp Donkey Aficionado
The 550 horsepower FRPP / Whipple supercharger package is rated at 550 (crank) horsepower at 10-12 lbs of boost. I was merely stating the obvious -- in order to achieve that power output with the 5.0L, you should only need 5 or 6 pounds of boost. The sophisticated adaptive tune and knock sensors will definitely come into play, especially considering the Coyote's 11:1 compression ratio.
Old Dec 28, 2009 | 12:45 PM
  #84
MARZ's Avatar
Exactly. The people wanting to run a 3.4L Whipple at 24 pounds of boost making 850 horsepower will still have their GT500, albeit with a different block material.
For the rest of us, there's the new 5.0L Mustang GT.
Old Dec 28, 2009 | 12:47 PM
  #85
Tony Alonso's Avatar
Also as stated in other places, standard GT brakes will be 13.2" in the front with twin piston calipers. Up about half an inch from 2010 correct? And then the V6 should get last year's GT brakes correct?
The front rotors are up almost an inch (12.4 -> 13.2) and are larger than the SN-95 Cobra/Mach 1/Bullitt rotors (13.0). Cool!
Old Dec 28, 2009 | 02:29 PM
  #86
Thomas S's Avatar
What does that have to do with anything?
Old Dec 28, 2009 | 02:37 PM
  #87
eci's Avatar
eci
It has to do with you can never have enough boost! That was the point, I didn't get the "5 or 6 psi is all you need " comment.
Old Dec 28, 2009 | 02:50 PM
  #88
zzcoop's Avatar
"Need" and "want" are two completely different things.
Old Dec 28, 2009 | 03:15 PM
  #89
Boomer's Avatar
It doesn't weigh those weights guys, come on..lets be serious
Also, what Marz's meaning, is you won't need the ammount of boost to achieve the same goals on the 3v 4.6 (asside from the 0.4L advantage)
The engine is on a completely different playing field.
Even a 5.4 being as over engineered as it is, if it had the new tech of the 5L family, ungodly ammounts of power could be achieved, ... and lighter.... so what could a 5L do potentially?
Hold on to your hats kids
Old Dec 28, 2009 | 03:17 PM
  #90
PTRocks's Avatar
'Beep! Beep!'
Old Dec 28, 2009 | 03:22 PM
  #91
Hopefully it doesn't, but one might reasonably expect some weight gain. I do find it curious that the quoted values in the spec sheet are in GT500 range. Perhaps it was a misquote.
Old Dec 28, 2009 | 03:26 PM
  #92
Boomer's Avatar
It doesn't.
Happy now
Potentially yes I guess it could if you add glass roof+shaker1000+all the bells and whistles+Oprah options
Old Dec 28, 2009 | 03:53 PM
  #93
3Mach1's Avatar
I honestly think Ford is taking a poke at GM with their "estimates" and rubbing it in. As good as the Camaro is weight in its current form is a killer. Camaro5 already locked one thread about weight. They just cant wrap their heads around reality.
Old Dec 28, 2009 | 04:16 PM
  #94
eci's Avatar
eci
To be honest, the mods here would lock threads that were a mirror image.
Old Dec 28, 2009 | 04:24 PM
  #95
stangfoeva's Avatar
I don't think so man. You don't even notice the mods here unless you need them. Which is a VERY GOOD thing IMO
Old Dec 28, 2009 | 06:35 PM
  #96
RandyW's Avatar
Besides the weight, there is another thing in that spec sheet that I question. If you look at the official photos of the 2011 GT it has the 18" polished aluminum wheels that are optional on the 2010's. The spec sheet describes two different 18" wheels and both are painted, not polished.
Old Dec 28, 2009 | 06:44 PM
  #97
3Mach1's Avatar
Big brakes are a good thing. Tony, I know you own or owned a Mach and S197. The brakes on my Mach are as good as anything I have ever driven. Bear in mind I have not drove ultra high performance cars like Vettes so I dont have much to draw on experience wise. I have driven a S197 quite a bit and felt they were not quite as strong. One reason in my case the S197 was a auto and a vert with much more weight. These 2011 cars will probably weigh in 150- 200 lbs more give or take than a mach 1 and need a slightly bigger brake.
What is your opinion and experience. I never thought I would see the day that brakes were so important to me. I must be getting old. My 67 stang had drum brakes all around and if you went through a water puddle they would grab and do all sorts of crazy things. Anybody remember those days?
Old Dec 28, 2009 | 09:01 PM
  #98
I was 2 at the time of the '67 Mustangs, so I missed the crazy drum brake action of those Mustangs.
However, I will say this about the Mach 1's brakes (which I still have) and the now 2 S197s I've had (trade-in '07 and recently purchased '10) - the brake feel on the Mach brakes is more firm than the S197. Also, there is probably about an 80+ lb difference between the Mach and the S197 GT, so it is not a huge amount. However, in both cases, if driving in extreme high performance situations (road course), both of the stock systems fade out. On the street, it's hard to tell which brakes are "better", other than to notice the pedal feel and the G-load when you brake hard.
The larger rotors are good since the GTs will now have a power level much higher than the current one or even the Mach 1s. It will be interesting to see how they resist fade when they heat up under hard driving.
I did a brake upgrade on the cheap on the Mach by getting a new set of stock rotors (made by Brembo), Hawk street performance pads, stainless steel brake lines for the front, and higher temperature brake fluid. This is for periodic road course driving (high performance driving events) where I can run for a little longer than when using the stock brakes and not worry about fade early in the session. If I was weekend racing the new '11 GT, I most likely would be looking at the Brembo upgrade (calipers + 14" rotors), along with a performance-oriented pad.
I think the bottom line is that for street driving, a larger 13.2" rotor is a solid change for the better to account for the 2011 GT's performance potential.
Old Dec 29, 2009 | 11:21 PM
  #99
3Mach1's Avatar
thanks for the run down. If the new Gt is as good as the Mach 1 brakes I will be happy. I am very very pleased with how good they are.
Old Dec 30, 2009 | 09:26 AM
  #100
Falchion's Avatar
So Tony, do you think the Brembo brake package on the 2011 would be worth going for, or would the stock brakes be good enough? I wasn't planning on driving mine on the track or anything. lol
