2011 Mustang Info.
Old Dec 27, 2009 | 10:20 PM
SynisterGT's Avatar
Originally Posted by eci
Anyone see this?
BASE CURB WEIGHT
(POUNDS)
Manual transmission 3,875 (est.) 4,000 (est.)
Automatic transmission 4,000 (est.) 4,000 (est.)
Weight distribution (f/r) 54/46 (est.) 54/46 (est.)
1st # is coupe, 2nd vert
NO S**T HOW THE HELL DID THE STANG GAIN 500+POUNDS.
Old Dec 27, 2009 | 10:21 PM
stangfoeva's Avatar
MOTM Committee Member
Is anyone else as surprised as me? I thought it was vaporware?
2010MustangGT's Avatar
Anyone see this?
BASE CURB WEIGHT
(POUNDS)
yuuuuuuuuuuuuuuuuuuuuuuup. Tho I can't imagine it to be true...the body is 97% the same... the engine is only 10lbs heavier. Grossly over estimated- just as the v6 was.
Fazm's Avatar
no way its going to weigh that much, they also said v6 waas 3700 when ford said under 3500 for perf pack one
SeanPlunk's Avatar
Anyone see this?
BASE CURB WEIGHT
(POUNDS)
It was like that on the V6 announcement too. It looks like just generic numbers.
Wolfsburg's Avatar
Zing!
Old Dec 27, 2009 | 10:22 PM
eci's Avatar
eci
More like 300.
PTRocks's Avatar
one more noteworthy pic.
Originally Posted by Ford
Development test engines and benchmarks included 5.0-liter blocks, employing different bore and stroke measurements, GT500 four-valve-per-cylinder heads and cams, various intake manifold runner configurations, differing compression ratios and a deep-sump oil pan. The team also evaluated Ford Racing’s 5.0-liter “Cammer” V-8 crate engine for transferable best practices.
The resulting all-new aluminum four-valve-per-cylinder heads feature a compact roller finger follower valvetrain layout leaving more room for high-flow ports for free-breathing performance. Head structure was designed to support higher cylinder head pressures and cross-flow cooling for sustained high-rpm use. Head bolt size was increased from 11 to 12 millimeters to contain the higher combustion pressures.
The aluminum block was developed for optimized windage and oil drainback under lateral conditions and high rpm, such as a track-day outing for an enthusiastic owner and driver. Increased main bearing bulkhead widths and nodular iron cross-bolted main bearing caps with upsized bolts were also employed to accommodate the significant performance increase.
Specially designed tubular exhaust headers were developed to maximize exhaust pulse separation and improve flow. A team analyst actually fabricated the tubular headers in his home workshop, bringing the CAE design to life.
Old Dec 27, 2009 | 10:23 PM
SuperSugeKnight's Avatar
Originally Posted by 2010MustangGT
"91 octane recommended."
Recommended not required.
KatarHol's Avatar
Anyone see this?
BASE CURB WEIGHT
(POUNDS)
Well,i was excited about the car for about 5 minutes....hmm,that was quick.I'll go back to drooling over the Challengers.
Old Dec 27, 2009 | 10:24 PM
stangfoeva's Avatar
Originally Posted by Wolfsburg
Zing!
I had too lol
But yeah like everyone else is saying I think those are just general numbers on the weight until everything is finalized. Of course the camaro boys will love pointing it out though lol
Old Dec 27, 2009 | 10:26 PM
SynisterGT's Avatar
More like 300.
My bad over reacted. lol
Old Dec 27, 2009 | 10:27 PM
MARZ's Avatar
Swamp Donkey Aficionado
I had too lol
Exactly. Where would the 2011 model have gained 300 pounds? The 5.0L weighs the same as the outgoing 4.6L 3V and the rest of the structure is carried over from 2010.
eci's Avatar
eci
My guess is 3700 for a well equipped manual. 3625 for a stripper.
Old Dec 27, 2009 | 10:28 PM
Well it's interesting that they list the automatic equipped coupe and vert as the same weight. They could have added bracing and stiffening components to both models...but either way they shouldn't weigh the same.
eci's Avatar
eci
Could pickup 75 lbs in the trans alone. 3650 was light because it is a weak POS.
But, normally people like to the take doctor's recommendations...
Old Dec 27, 2009 | 10:29 PM
MARZ's Avatar
True... we still have 225 lbs to account for.
Old Dec 27, 2009 | 10:30 PM
MARZ's Avatar
Recommended if you want its advertised output of 412 hp and 390 lb-ft of torque.
Old Dec 27, 2009 | 10:31 PM
  #40
SynisterGT's Avatar
15 days til Detroit. Can't wait to see the new wheels as well as the CS.
Glad I'm waiting to get one of the best Mustangs in history.
