2011 6-speed manual skip-shift feature
Old Oct 28, 2011 | 12:01 AM
  #81
Will3212's Avatar
skip shift is not a problem for me, I thought it would be when I bought the car. I never disabled it.
Old Oct 28, 2011 | 10:52 AM
  #82
2012GTCS's Avatar
I also notice a rattle from the tranny/shifter when I go into too high of a gear. Anyone know what that sound is?!
I just hate sounds in tHe car that aren't "normal" and I like to know what it is when I'm hearing it...
Old Oct 28, 2011 | 10:56 AM
  #83
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
That would be your gears binding because you went into them too early
Old Oct 28, 2011 | 12:41 PM
  #84
AzPete's Avatar
The rattle could be from the engine....pinging because of to low of an rpm for the gear chosen.
Old Oct 28, 2011 | 12:50 PM
  #85
Bear Eats King...
Bear ****s Bone
very possible
Old Oct 28, 2011 | 03:17 PM
  #86
2012GTCS's Avatar
So long story short, it can be harmful to your car. Which also means skip shift is harmful for your car. Don't know about u guys but everytime skip shift goes from 1-4 I get the bogging/rattle. The rattle seems to come from the shifter area. Bearing maybe?
Same thing with Starting in 2nd, unless I give it a good rev first...
Old Oct 28, 2011 | 04:09 PM
  #87
AzPete's Avatar
Unplug skip shift and don't worry. Most likely nothing wrong with yours.
Old Oct 28, 2011 | 04:17 PM
  #88
FLAstangx3's Avatar
What he Said!! UnPLUG THAT Sucker!!!!!!
Old Oct 28, 2011 | 04:23 PM
  #89
whoah's Avatar
I'm kind of liking the idea of skip-shifting into 3rd instead of 4th, even though the coyote has the torque to hit 4th at 17mph, I really do feel that it's kind of early for 4th. I'm kind of old school, on my old 4 speed f100 with the I6, I'd do 1-2 at 10, 2-3 at 20, and 3-4 at 30
Old Oct 28, 2011 | 08:23 PM
  #90
2012GTCS's Avatar
I sometimes do 1-3-5 when driving easy. Works perfectly and smoothly. 1-4 is just way too much of a jump IMO
Also is regards to the bogging noise I was asking cause sometimes I'll stay in 3rd when doing a lazy stop at a stop sign and get the same sounds. Just wondering of this was causing any harm.
Old Oct 28, 2011 | 08:38 PM
  #91
AzPete's Avatar
When an engine pings or rattles under load, it is not good. Once in a while is no problem but doing it all the time is bad.
Old Oct 28, 2011 | 08:57 PM
  #92
2012GTCS's Avatar
Hm guess I have to make sure I downshift to a lower gear then.
So then how do people say they always start in second gear with no issues?!? I have 373s and it happens everytime I start in 2nd unless I really give it a good rev which then makes it pointless to start in 2nd anyway...
Old Oct 29, 2011 | 07:18 AM
  #93
AzPete's Avatar
Yep....starting in 2nd requires a bit more rpm and clutch slipping to get rolling. Some start in 2nd so they eliminate one shift so soon. I prefer 1st....then I will skip a gear if I feel the need. So far, skipping gears has not made me rich from the gas savings......and I bought a manual so I could shift....
Old Oct 29, 2011 | 11:11 AM
  #94
tetstang's Avatar
Can Skip Shift be de-programmed at the dealer? (You know. . . pulling plugs, warranty denials...that sort of concern..on my part)
Old Oct 29, 2011 | 12:22 PM
  #95
AzPete's Avatar
Getting a tune is the only way I know of de-programming it....then the warranty may go out the door. Just unplug it......so easy.....see no possible warranty issues.....Ford knows mine is unplugged and has no issue.
Old Oct 29, 2011 | 08:51 PM
  #96
Frosty the Snowman's Avatar
Unplugged mine the 2nd day I owned my GT.
May 3, 2026 05:42 AM
TripleBlack14
May 10, 2016 04:30 AM
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
