2010 Rear Sway Bar Links
Good evening everyone!
This is my first post on here, and I had a question regarding my 2010 gt rear sway bar links.
The old ones needed to be replaced and the new ones that I put on are not as tight (rubber fitting isn't as tight on the bar). I have a 22mm sway bar and even measured it out (22.6mm).
After measuring the inside of my new MOOG K750139's, the diameter is about 25.2mm on one and 24.7mm on the other. So my questions is, did I receive 2 defective products that are the wrong size? Or is it normal for there to be a little bit of play between the rubber and the bar so people can slide it on without an issue?
Thanks for your time!
-Tyler
-Tyler
The sway bar diameter was dependent on which model mustang you have, for example the GT had bigger sway bars than the V6's. The sway bar end link bushings should fit snuggly. it sounds like the bushings you have a for a larger diameter sway bar.
The should fit snuggly. Play leads to clunks and rattles. I have the Steeda end links/bushings and there is no play at all. Others have had issues in getting bushings to fit the stock sway bars and end links. Some have purchased after market end links and bushings such as the ones from Steeda. They will provide the proper size bushings if you specify the correct size.
KonaMustangGT
Feb 11, 2017 01:34 PM
sam strano
Nov 11, 2011 04:01 PM
sam strano
4.6L GT Modifications
Nov 10, 2011 06:49 PM
perfect storm
May 6, 2010 04:54 PM
