2010 Black Horse
2010 Black Horse
Heys guys not sure if I asked this before but i wanna get the 2010 black horse emblem for the front and was wondering if anyone has ever taken that off? i see it has like little compression ***** or something. Is it hard to pop off? thanks in advance.
Yeah it's a pain in the *** to pop off, I actually broke the tabs on the back of my factory horse trying to get the washers off, but I figured no big deal since I was putting the black one on anyway.
I did this swap a few months ago and go the part from Partscheap.com and would definitely buy from them again. The swap is a little annoying because of how tight those little friction washers are on the plastic posts. I ended up cutting the posts very close to the washers and the washers popped right off after that. I used some new friction washers I picked up from Lowes instead of the factory ones, I just couldn't get them back on without pulling the entire grille off the car and applying serious pressure to them.
Its a PITA! My fingers hurt for 2 days after putting those washers back on. I did get a tip from someone on here to use am 8mm socket to pound them back on......
I have the black pony as well. Its really not the bad as long as you dont mind destroying the old one. You can just break the tabs off the old emblem, pull the pressure washers off and apply them to the new emblem with a 8mm socket to help push them on.
Darn it, Steve... that is one hot shot there of your Stang! My Boss Splitter is on its way to Florida and should be here by the beginning of the week. Just have to get the CS fascia now... still shopping around for the best price... LMR has it, but $ 135 for shipping is a bit steep and actually can pick the part itself up cheaper at the local Ford dealership.
Maybe I'll just have it installed... saves me any potential PITA!
