Power & Heated Seat Wiring Info 2005-2006 Vs 2007-2009
The Analog Admin!
Received 2,959 Likes
For Those who want to Know! Here are 05,06 & 07 Mustang Power & Heated Seat Wiring info.
UPDATED PDF FILES POST 7 05&07
KC 01/04/24
Enjoy!
KC
KC 01/04/24
Enjoy!
KC
so we use this to hook us a voice box with pre programed sounds when an occupant sits in passenger seat ? Hey could the ambient lighting be added to my 07 for cup holder or is it more extensive ?
The Analog Admin!
The Money Shot. The Diff Between Seat Harnesses
VGMStudios (3/23/24)
I did this mode - wasn't a big deal. And well worth the price for the added comfort to my wife.
I also did the ambient lighting - little more fabricating of brackets and harnesses here.
Cheers
Cheers
Necro thread, I know, but I do know you are still on this board on occasion. I just picked up a power passenger seat bracket for my 2005. Holy cow there are a lot of wires. I don't have airbags. What wiring do I actually need to power the seat? I can get the OCS plugs and such but there are something like 20 wires in the main plug. Any ideas? Hoping you will remember your 11 year old mod.
The Analog Admin!
Updated Power Seat Wiring For 2005 to 2007 Power Seats!
Also SRS Info!
KC
Also SRS Info!
KC
The Analog Admin!
The 06 Up Passenger Seat Track is Still Available as an FYI and it is Supposed To Be Plug & Play on 2006-2014 Originally Equipped With a Power Passenger Seat.
Cataloging Indicates 2005 Was a One Year Wonder. But If I Recall the 05 and 06 Had Different Wiring To Body But Wiring To Motor From Body Wiring May Also Be Different Between the 05-06.
But Wiring Aside The Later Track Should Be Adaptable as Add on to Any 2005-2014 With Wiring Mods. If You Are Simply Needing a New Replacement Punch in Your Vin To See Which Track You Show.
Part Number Supercession Chain Original Part 6R3Z-6361711-AAA, Replaced by 7R3Z-6361711-A Replaced by AR3Z-6361711-A
https://www.fordpartsgiant.com/parts...tra2=&filter=()
Also As An FYI! The Elusive Seat Track Repair Kit!
https://www.fordpartsgiant.com/parts...8617d66-a.html
KC
I Would Advise Finding a Car at a Pic a Part With The Same Color Side Shield and Cut The Wiring as Far Up The Car as Possible. Be Advised The Seat is Going to Be Stuck in Whatever It's Last Passenger Had it Set To and It May or May Not Pose Problems Getting At Certain Bolts. Also Be Advised The Sight Shields are Quite Fragile and Better Removed After Seat Track Removed if Possible. As Far as The Low Down on The Sight Shields Here it is on the Link. The Low Down If You Need To Replace It.
Here is My Thought on The Passenger Seat Track. Many Stangs Were a Lone Wolf Car Meaning Hardly Anybody Rode in Passenger Seat. So I Would Try & Find a car Where The Passenger Seat Was Really Nice Regardless of If Drivers Side Was Tired. Although Overall Nice Interior Condition Would be a Plus Because a Dust Filthy Interior Would Tend To Gum Up The Work in a Power Seat Track.
Might Want to Do dry Run On Your Drivers Seat For Removal So No Surprises on What tools Will Be Needed.
https://themustangsource.com/forums/...umbers-549349/
KC
jaguarking11
Ford OEM Parts {Oem Ford Parts Information & Links}
10/15/08 03:07 PM
