White smoke
Old May 16, 2013 | 06:44 AM
Dbranham's Avatar
Need help,
This morning I went to start the car and it wouldn't start, figured I was out of gas. So I grab one of our gas tanks and put 1-2 gallons of gas into.
Now it has gas to get me to a gas station.
Go to start it, it starts, after pumping the throttle.
Car is started at this point, idles smoothly and everything seems normal
Now here is my problem. I get out and notice a lot of white smoke coming out of the exhaust, I leave it to idle while putting gas up and grab some stuff. Get back, it's still smoking. So I turn it off and leave it and take my truck instead.
So, could a head gasket gone bad. Or could I have had some bad gas that I put in it.
Need some input on what it might be and what I can do to find out for sure what it is.
Old May 16, 2013 | 07:19 AM
shaunrc's Avatar
Originally Posted by Dbranham
Need help,
White smoke is a sign of burning coolant which typically is a blown head gasket. a fuel problem, if smoke was present , would burn black smoke. Is your coolant abnormally low and it should smell sweet if your burning coolant
Old May 16, 2013 | 08:41 AM
Dbranham's Avatar
This was the first start up after getting the car back from getting a new water pump.
Old May 16, 2013 | 08:52 AM
shaunrc's Avatar
That won't have anything to do with it you are getting smoke from the exhaust (combustion chamber) if you want to run some sea foam through it and let it run for a while and see of it goes away
Old May 16, 2013 | 08:59 AM
Dbranham's Avatar
Down sides of driving it of it is a bad head gasket?
Old May 16, 2013 | 09:09 AM
shaunrc's Avatar
I wouldn't drive it just let it idle for a bit so I would fill radiator let it run smell the exhaust a little into it and if it smells sweet and coolant is low you know you have a bad head gasket
kponypower
Jun 17, 2020 07:17 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
09-gt/cs
Oct 15, 2015 10:03 AM
