White smoke
Need help,
This morning I went to start the car and it wouldn't start, figured I was out of gas. So I grab one of our gas tanks and put 1-2 gallons of gas into.
Now it has gas to get me to a gas station.
Go to start it, it starts, after pumping the throttle.
Car is started at this point, idles smoothly and everything seems normal
Now here is my problem. I get out and notice a lot of white smoke coming out of the exhaust, I leave it to idle while putting gas up and grab some stuff. Get back, it's still smoking. So I turn it off and leave it and take my truck instead.
So, could a head gasket gone bad. Or could I have had some bad gas that I put in it.
Need some input on what it might be and what I can do to find out for sure what it is.
Need help,
That won't have anything to do with it you are getting smoke from the exhaust (combustion chamber) if you want to run some sea foam through it and let it run for a while and see of it goes away
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
