What's the difference?
Old Nov 1, 2005 | 12:22 AM
Mestizo's Avatar
I'm just curious what's the difference between the T5/T-45 and Tremec 3650?
Seeing as how the Tremec 3650 was used in the latter years of the SN95, what made it "superior" or better than the T5/T-45 model?
I guess a side question would be, is there a difference between a T5 and T-45?
Don't know why these questions popped in my head, but now they are making me curious.
Old Nov 1, 2005 | 06:45 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
The 3650 is stronger, it has a higher torque capacity rating, although still not as strong as a built transmission made for high hp.
There is a difference in the t-5 and t-45. One of the main things, the t-5 tranny can be removed from the bellhousing while the bellhousing is still bolted the car. It was what 5.0 based cars used.
The t-45 acctually is a slightly stronger version of hte t-5, but you could not remove the tranny from the bellhousing while in teh car, you had to remove the tranny/bellhousing as one part, then the bellhousing seperates with bolts on the inside of it. a PITA. It was put in to action in the 1996-2000 4.6L years, and in 01 they swapped to the 3650. I think when the t-45 first came out, it was made by borg-warner, and then tremec took it over in '99, but I could be mistaken by that.
Old Nov 1, 2005 | 10:09 PM
bob's Avatar
bob
3650's also have an intergal bell housing, its the face plate for the tranmission, I also believe that the TR3650 had a problem with 2nd gear synchros and there might be a TSB (IIRC)
CoyotePremium13
Oct 7, 2015 07:17 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 11, 2015 08:39 AM
