Speedometer Shop Manual PDF for bouncing speedometer needle on my 2000 GT
I noticed the speedometer needle bouncing when I come to a stop, and going into neutral. It jumps from zero to random values. I did some searching and some have suggested that it may be a broken cluster (everything else seems to be working), and also a bad cable (that it may need to be greased). What type of grease to use on a cable - and do 2000's even use a speedo cable? Also, does anyone have a link to show how to access the speedo cable?
Furthermore, are there any available downloadable factory service manuals online for the SN95 mustang?
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
Speedometer Gauge
The instrument cluster receives the vehicle speed signal from PCM over the SCP network and displays it on the speedometer gauge. If the instrument cluster receives no vehicle speed signal after one second, the speedometer defaults to 0.0 km/h (0.0 mph).
I pulled up a shop manual but 04 is the earliest I can get in PDF Format.
KC
KC
Puny Little Thread But With 2500 Pdf Downloads!
Not Bad!
KC
Not Bad!
KC
